Old 10-06-2017, 12:42 AM   #1 (permalink)
The Popsicle - '00 Nissan Frontier Regular Cab XE
Last 3: 25.91 mpg (US)
Hello! Another new one!
Hey everyone!
I often frequent this forum for fuel economy advice and I figured I might as well join! I am Theo, and I drive a 2000 Nissan Frontier compact pickup. It's a regular cab, 2.4L 4-cylinder, 5-speed stick shift with roll-up windows a bench seat. We are talking real, real basic here. I would like to eek out more fuel economy out of the little truck. My last fuel mileage calculation was 25.91 MPG. My goal is to adjust my driving style to drive more efficiently. As for the purpose of the vehiclec, it's currently my daily commuter to and from college, 20 minutes away.
Here's how small it is.
One question though.
Since the bed is an open empty space most of the time, does this create more aerodynamic drag? Would it help some if I added a tonneau cover over it?
Thanks for reading...
Theo T.
Old 10-06-2017, 10:20 AM   #2 (permalink)
Welcome to the site Theo.
Old 10-06-2017, 11:06 AM   #3 (permalink)
JockoT's Avatar
All That Jazz - '06 Honda Jazz i-DSI S
90 day: 48.72 mpg (US)
Welcome Theo. Tons of great advice to be had here. Suggest you start with the 100+ Hypermiling Tips at the top of the page.
People Think They Are Thinking When They Are Merely Rearranging Their Prejudices
Old 10-06-2017, 01:12 PM   #4 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Howdy,
As a member with a pickup similar to yours, there's a lot of improvement to be had.
As to whether a tonneau or cap is the way to go for you, that's difficult to say without some testing. I've had a full cap on the bed of my truck since it was new and it has delivered mid-30s fuel economy on many occasions.
You could rig up a quick and dirty tonneau of sorts with a simple lumber framework in the bed to support a coroplast lid. Run your truck a few tankfuls without a lid, then a few with, then a few without for A-B-A testing.
I guarantee the underside of your truck is an aero disaster and there's no end of improvements to be had under there that, in addition to serving you well at the pump, won't detract from the vehicle's appearance. If you don't want to go to the full belly pan, a deeper air dam may suffice to give you significant improvements.
I think your truck's generation still had an engine-driven fan. Replacing that with a thermostat-controlled electric one will take a lot of load off the engine. An electric will only run when necessary, leaving a lot more power than you ever imagined at the crank for moving the vehicle. Generally the electric fan will drop out when you're moving, and only fire up when the vehicle is paused or at very low speeds.
Like the other guys said, there are some stickies at the tops of these categories: Aerodynamics, Hypermiling / EcoDriver's Ed, and EcoModding Central. As you already mentioned, adjusting how you drive is the first step, and in terms of return on investment nothing else will come close: there's no money involved. Even now that's pretty much all I've ever done with my truck, and the results speak for themselves.
Welcome, and have fun with it.
Old 10-06-2017, 03:13 PM   #5 (permalink)
Sure a tonneau is going to lead to an improvement, most noticeably in highway. I'll have to second on elhigh's advice on an electric fan, since it's a fairly simple mod and leads to some good improvements not just in fuel-savings but also making it easier to reach the operating temperature in a shorter time after the start, leading to smoothier idling and also increasing the efficiency of the catalytic converter since the "cold phase" becomes shorter.
Old 10-17-2017, 12:50 AM   #6 (permalink)
Hello!
Thank you for all the replies. Special thanks for elhigh for all the tips and advice. My Frontier has a shaft driven fan since the engine is longitudinally mounted. I've seen the underside, and yeah aerodynamics are poor there. Plenty of gaps and spaces for sure.
Also I will need new tires soon. Tread is wearing thin What would you guys recommend for low rolling resistance tires? (P215 65 R15 size tires)
2000 Nissan Frontier Regular Cab XE 2WD
2.4L 2389cc 4-Cylinder Engine (Code: KA24DE)
5-Speed Manual
15-inch Steel Wheels
Old 10-26-2017, 12:37 PM   #7 (permalink)
The engine mounting doesn't prevent you from replacing the stock fan with an electric one.
Old 10-31-2017, 02:02 PM   #8 (permalink)
Master Novice
elhigh's Avatar
If you can find low rolling resistance (LRR) tires for your truck's size, I'd say go for it. I have LRR on one of my cars and haven't noticed any kind of lack of traction or longevity, and I know from painful experience that I lost a LOT of fuel economy when I ran light truck tires on my truck. I lost about 15% overnight, and it stayed gone until I replaced the tires. Never again!
Tire Rack usually gives a tick box for LRR, so you could shop makers and models with that specified and see what pops.
My truck's native tire size is 195; if yours can take a narrower tire (especially if you can find a size that keeps the overall height correct) then you could pick up a couple of points there, too.
