Old 10-09-2009, 04:23 PM   #1 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Rolling resistance ratings ( sort of ) in Consumer Reports
Just in case you all didn't know it, anytime that Consumer Reports tests a tire, they test its' rolling resistance.
The latest issue for example has an article on tires that gives a rating for rolling resistance on all tires tested in the article.
The catch ... the rating given for the tire is not numerical, but rather the standard practice of giving a product a certain number of stars ( or dots in the case of Consumer Reports ).
Where I see hope in this is that they might possibly be willing to share the actual numerical data if requested . ( hmmm... or not )
Anyone subscribe to C.U. here ? I doubt they would give the information to a non subscriber.
Online tool: shows aerodynamic drag, rolling resistance, power required & est. MPG MetroMPG Aerodynamics 100 12-30-2022 06:25 AM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 46 06-05-2015 04:24 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Calculating Rolling Resistance SVOboy EcoModding Central 2 02-15-2012 08:43 PM
