Old 07-24-2010, 07:37 PM   #1 (permalink)
Reducing the energy loss due to A/C
Why do car makers not heat and cool our cars like we do our homes? In my home during the summer, I don't regulate the temperature in a room by running the A/C all of the time and when it gets too cool I turn on the furnace, I just turn off the A/C. Why do we regulate the temperature in our cars by running the A/C all of the time at maximum power then moderate the temperature with hot water from the engine. Why not automatically cycle the A/C on and off to maintain the temperature like your furnace does at home in the winter?
This is the technique that I use to help reduce fuel consumption, but making it automatic would allow the manufacturer to raise their CAFE ratings.
I'm sure that it wouldn't cost too much since you already have temperature sensors all over your car already. And software doesn't add weight.
Old 07-25-2010, 08:38 AM   #2 (permalink)
The PRC.
The hot water from the engine is there all the time anyway, so no additional energy in making that.
Some cars with climate control with air con do that automatically - turn the AC on and off. You can cycle your air con manually to do the same thing. I've seem some advice about not running it when accelerating in a low power car.
Old 07-25-2010, 04:02 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
rbrowning -
What Arragonis said. Newer cars (not mine) are cycling the A/C to save fuel.
CarloSW2
American Solar Energy Society
Old 07-25-2010, 11:42 PM   #4 (permalink)
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
Pop your hood and run your AC full tilt. You should see the AC clutch engage and disengage as needed. This does mean that the AC is not running all the time. As for heat, like it was said above.
Old 07-26-2010, 01:05 PM   #5 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Some cars also control the A/C by TPS% although the ones I have seen are set to high (from factory) like turn off at 94% throttle.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 07-26-2010, 07:49 PM   #6 (permalink)
I realized that the heat was "free", but I was not aware that the A/C compressor was cycling. I turn mine off and on manually to maintain a reasonably comfortable temperature and have been doing so for years. I have never heard my engine speed change so I'm not sure if the A/C isn't drawing much power or if it isn't cycling off and on.
Old 07-27-2010, 10:43 AM   #7 (permalink)
...beats walking...
TSV = "Throttle Suction Valve" modulation, for those wondering.
...part of "automatic" A/C control system; TPS is part of "engine" control system.
Old 07-27-2010, 02:24 PM   #8 (permalink)
Phantom's Avatar
TPS = Throttle position sensor
Or at least thats the only way I have seen it used.
Old 07-27-2010, 03:20 PM   #9 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
Your method of manually cycling on and off does work most economically, but it can get annoying on a long trip.
In my van (with manual controls) I run the blowers until a comfortable temp is reached, then turn the blowers down to minumum setting. There are temp sensors designed to keep the condensor from freezing up, and by slowing down the air flow, the condensor gets cold faster, and cycles the compressor off more frequently. Most of the time this maintains a comfortable temperature.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 07-27-2010, 03:27 PM   #10 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Before I had cruise control added to my car, I had never been able to spot a difference in FE with or without airco.
On CC however, fuel consumption will instantly drop 0.2 to 0.3 L/100 km - around 6% - when shutting the AC down - that's a 3 mpg increase in FE.
Anyone tried HHO on a diesel? j.kansas EcoModding Central 99 07-28-2015 07:17 PM
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Geothermal energy? DifferentPointofView Saving@Home 46 02-05-2009 10:15 PM
