Old 06-03-2008, 04:41 PM   #1 (permalink)
Sandstone Princess - '99 Chevy Sububan LT
90 day: 21.04 mpg (US)
Joe - '02 Nissan sentra XE
90 day: 43.9 mpg (US)
Regal - '03 buick Regal LS
90 day: 33.85 mpg (US)
What changes in computers/ecm?
OK, I've just picked up a Jet DST programmer for my '99 suburban 2wd and 03 regal. What are the best know parameters to modify or change in order to see mileage improvements? I have already done some work on the suburban, dropped idle rpm by for most temps and bumped up timing four degrees from 2000rpm and 20kpa down. I plan on running some logs via auto-tap and see where the engine load and timing are during 70-75mph cruise settings. The software can touch pretty much every table within the ECM.
I have removed the roof rack and installed an efan with positive results. Just the roof rack and and new michellin tires yield 21-22 mpg (scangauge) on the highway.
Where should I start tuning for max mpg on this thing?
Old 06-04-2008, 11:40 AM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Hi klrv6 -welcome to the forum.
I can't answer the question (not a PCM expert), but there are a couple of members on the board who are. Hopefully they'll see the thread and pipe up.
Old 06-04-2008, 07:04 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Welcome to ecomodder! I played with tuning a while back but didn't really get anything, think you need a dyno, some money, and some time to really get anywhere with timing and afr tweaks.
Old 06-04-2008, 07:12 PM   #4 (permalink)
Pushrod - '02 Chevrolet Cavalier
The stock program is unable to run anything in closed loop but 14:7:1. GM has a lean cruise mode on ROW ECUs. If you can reflash your ECU or get a ROW unit (if they exist), you will pick up a few MPG highway. I can guarantee that you'll see substantial savings by dropping from 75 to 55mph.
