hot fuel vs. cold air
ive been thinking about this. you can have a hot air intake to heat the fuel up so the gas burns better or cold air because its more dense then hot air.
but the i found out for every 25 dreases you heat the fuel up is one mpg and for cold air its every 11 dreases colder its one mpg if i remember right so my q is this has anyone tested this?::D |
*) This is true only for gassers. Diesels like cold intakes for both power and FE. |
I have found that heating gasoline to 180 deg. F yields about a 10% return improvement in fuel economy. Detonation threshold seems about the same for a given octane value. Greater tendency to vapor lock during hot restart. Most OBII ecu s have the ability to recognize this condition and will keep injectors closed until engine restarts. May take 2 or 3 tries but it will fire up. Heating intake air also improves fuel economy but I have found a greater tendency to go into detonation especially when ambient temps. go above 60 deg F. If you run a dedicated water or water/methanol system you can effectively supress detonation with even the lowest octane fuel.
Diesel or gas?
10% cool :D is there any way that can hurt my truck??? if not sounds like im going to be heating some gas do you use the coolant? to heat it |
probably not
all systems run most of the time at an
Air to Fuel ratio of 14.64 to 1 1 part fuel 14.64 parts air by weight so 1 part of fuel will have much less influence on the temperature of the complete mass entering the combustion chamber than the 14.64 parts of air and on systems that have a return line that extra unused very heated fuel goes back to the fuel tank , heating the fuel in the tank which causes heavy duty evaporation and pressure build up in the fuel tank much of that pressure and HC can be vented to atmosphere because most systems are not designed to handle that scenario fuel vented to atmosphere does not increase FE as it is wasted 10% improvement .... not very likely Quote:
your right!!!!!!!!! but what if we bypass the return line? |
I would listen to mwebb - heating fuel will probably have little effect on anything. |
PS--mine's turbocharged--would that make a difference in optimum air temp for FE? |
