Old 01-16-2021, 08:34 PM   #1 (permalink)
Rake Back to save MPG
Has anyone Lowered the back of a fullsize van(15 Passenger) to create a Kammback Profile? I think I could get approximately 3 ° with 6" drop on rear axle . This would Make the very Back of the van 8" lower. This May also improve the windshield angle. it would lower Back of the van. I would add air Dam and ground effects to clean up the airflow under the van. I also Plan on adding My 1 wheel Kamm Back trailer Behind it.
Old 01-16-2021, 08:45 PM   #2 (permalink)
A slant chop would have the effect you want.
A tail-dragger stance would IMHO add drag, unless there is a full bellypan.
The more general question would be forward, neutral or reverse rake.
edit:
There is ecomodder.com/forum/showthread.php/deep-blue-suburban-streamlining.
He is adding plan taper. I think it's more work than a slant chop. Last post in December.
Old 01-17-2021, 09:43 AM   #3 (permalink)
Thanks for your thoughts. I was hoping to maintain the interior dimensions But wondered if a 3° slope would help or if I should try dropping it's total height by lowering the suspension. I definately want to clean up the airflow Underneath the van.
Old 01-17-2021, 12:26 PM   #4 (permalink)
Height does not equal frontal area.
Lowered with an air dam is the quick and easy solution; a full bellypan with wheel spats would probably give a better result.
