Old 11-02-2014, 12:14 AM   #11 (permalink)
Originally Posted by 2000mc View Post
would a group 31 AGM battery fit on its side?
The first time that I remember changing a car battery, I had my little brother carry it into the store. The employee said "Hey! Watch it! He is going to get battery acid on him!"
I had him set down the battery, took him into the bathroom, and washed him off.
His clothing suddenly had holes.
Cobb (11-02-2014)
Old 11-02-2014, 01:53 AM   #12 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
AGM batteries are dry. No water. Nothing to leak out. They can be used on their side just fine.
The Following User Says Thank You to mechman600 For This Useful Post:
Xist (11-02-2014)
Old 11-02-2014, 10:12 AM   #13 (permalink)
this isnt a cheap idea, and the work mounting may not be alot easier than making a trunk mount, but would a group 31 AGM battery fit on its side?
Yeah, I think it would probably fit on its side.
Old 11-02-2014, 10:13 AM   #14 (permalink)
Originally Posted by Cobb View Post
Those are nice wheels on the prius to the right. Is it yours?
Yep, the Prius is mine. My wife drives it typically. The wheels are just the stock wheels on any 2nd gen Prius. They have the trim rings removed because I modded them for pizza pans (which didn't end up working).
Old 11-03-2014, 09:25 AM   #15 (permalink)
What I'm currently thinking is that I have four LiFePo4 A123 amp20 (20Ah) pouch cells. I've always wanted to use them on a car because they are ridiculously light weight. I'm thinking of using those up front and fitting another lead battery somewhere else. I just have no idea where yet. I'll have to come up with some way of monitoring both batteries. Still not set on the idea, but its a possibility.
Old 11-03-2014, 01:46 PM   #16 (permalink)
I just emailed a local guy trying to get rid of some old Thundersky 200Ah cells with ~100 cycles on them. Yeah, they're massive overkill for an alt delete, but if he is willing to let them go cheap, I can make it work.
Still looking into options.
Dropping in a group 24 would still be by far the easiest thing to do and would suit most of my needs.
Old 11-03-2014, 03:15 PM   #17 (permalink)
I tried a couple batteries in the Metro this morning and it is looking like I have a height clearance problem...
I'd need lithium cells and a lithium charger at the least, possibly a BMS.
Modify your hood to look like you have a turbo.
Battery chargers are cheap.
Hobbyking
Old 11-03-2014, 04:21 PM   #18 (permalink)
Mostly for my own reference, these are the lead acid cells I'm looking into:
group 24, 80Ah, $72
group 27, 105Ah, $75
Ironically, the little 26R OE replacement costs even more than either of the deep cycle batteries above:
26R starting battery, $89
So, its actually cheaper to go with either of the batteries that'll allow me to do an alternator delete... Works for me.
Old 11-03-2014, 04:39 PM   #19 (permalink)
Hobbyking
Lol, a Metro with a hood bump... I'd laugh at that.
Old 11-03-2014, 05:09 PM   #20 (permalink)
Actually, I was thinking that you could modify your hood like Aerohead did trying to make the front more aerodynamic. I know that he did not see an improvement, but you could fit all kinds of batteries in there if you raised the roof!
Mostly for my owner reference, these are the lead acid cells I'm looking into:
That is a strange love note for your wife!
The Following 2 Users Say Thank You to Xist For This Useful Post:
mikeyjd (04-15-2015), Sven7 (11-06-2014)
