Old 11-09-2014, 12:34 AM   #11 (permalink)
Are you going to make a bump that's not off-center in the middle, or roll the edge to lift the whole face of the pan outward?
Old 11-10-2014, 03:36 AM   #12 (permalink)
spray2020's Avatar
any progress on these?
Old 11-11-2014, 11:36 PM   #13 (permalink)
LuvmyPIP - '13 Toyota Prius plug in base
90 day: 57.94 mpg (US)
I'm still waiting for the aftermarket center caps I ordered. I made the plywood punch and die and it works like a charm. To make them I made a compass out of my router with a block of wood and 2 pieces of 1/4" all thread rod, the compass center point is a 1/8" drill bit. The die is a piece of 3/4" plywood with a 15 1/2" diameter area routed to a depth of 5/16" (the 3/16" rolled edge of the pan sits on un-routed plywood). The punch is a 6" diameter piece of 3/4" plywood also made with the router-compass. After locating the center of the first pan I drilled a 1/8" hole in it and used the drill bit to align the punch, pan and die, set the die on flat concrete and gave the punch a few hammer blows. Presto it works!
I'm pretty well convinced that drilling and tapping 5 of the 10 spokes on a 6 1/2" radius circle with 6-32 screws located in the middle of the spokes will not compromise the wheels and give a really secure mounting. I'll still use a bolt through the center cap but it is essentially cosmetic but useful to speed re- installation. Now has anyone got an easy way of getting 5 equally spaced holes on a 6 1/2" diameter circle?
I plan on using rubber washers between the pan and spoke at each screw and using silicone RTV on the screws as a low torque thread locker and may add a very thin bead of silicone RTV around the perimeter of the pans.
Old 11-12-2014, 03:20 PM   #14 (permalink)
6.5 X pi = 20.4203522483336. Mark the circle using 4" arcs, once clockwise and once anticlockwise. Then with any discrepancy, split the difference.
