Old 03-19-2021, 09:21 PM   #1 (permalink)
Oyuki - '90 Toyota Corolla TX
How can i calculate the drag coeeficient with the height and width?
Good evening,
I would like to know how can i calculate the drag coefficient of a 1990 toyota corolla with the height and width measurements?
Thanks
1990 toyota corolla TX 1.8 Diesel sedan
40 MPG @ 50 km/h /31 mph highway
Old 03-19-2021, 09:48 PM   #2 (permalink)
I don't think you can. Cd is a dimensionless number.
en.wikipedia.org/wiki/Dimensionless_numbers_in_fluid_mechanics
At most you could estimate A, for area (~78-85%).
Old 03-19-2021, 10:55 PM   #3 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I can't find the source now, but I remember .32 as the cD on the car.
Although the car doesn't look sleek, the car was well designed for low drag.
By comparison, have a look at the VW Box ....I mean Fox
Despite the car looking like a box, it had a cD of .31!
This is better than a car such as this Firebird at .33 !
ID:	30314   Click image for larger version
ID:	30315   Click image for larger version
Old 03-20-2021, 12:09 AM   #4 (permalink)
"User name checks out."
Here's mine:
(I'm coming down on the selling price)
(...I'd even throw in the roof rack)
Old 03-20-2021, 12:27 AM   #5 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Force = velocity^2 x cross sectional area x coefficient of drag x the density of the air.
To find the coefficient of drag you need to know:
  • How dense is the air where you're at (usually 1.225 kg/m^3)
  • The cross sectional area. That's not just height and width. You have to take a picture of the front of the car from far away and use a bunch of geometry to figure out the actual area.
  • The mass or weight of the entire vehicle, including yourself and fuel.
  • The rolling resistance, although with enough testing you can kind of figure out both your rolling resistance and coefficient of drag.
  • And a way to measure speed and time to figure out deceleration.
Calculate your cross sectional area in meters squared.
Speed up pass a certain speed (i.e. 60mph) on a known flat piece of pavement and throw it in neutral. When the car slows down to that speed (60mph) start the timer. When it has dropped a small amount (i.e. 55mph, 5mph less) stop the stop watch. The more accurate your measuring instruments and techniques are the better the results will be. Several repeated tests are best. Try both direccions on the same road and avearage out the results in case the road isn't perfectly flat.
Now take your speed drop and turn that into meters per second per second (m/s^2). For an example, from 60 to 55mph is about 2.235 m/s. If it takes 1.5 seconds that about 3.353 m/s^2. Now take your weight and turn that into kilograms and multiply that by your m/s^2 to get force in newtons. Subtract any force you believe or know rolling resistance takes up. You could push a pressure operated scale against the car and see how much force it takes to push the car in neutral and convert the number into newtons. Or do a lot of tests at different speeds with different guesses until you find a rolling resistance number that doesn't change much at different speeds.
Take the average speed in m/s (between 55mph and 60mph is 25.7) and square it (multiply it by itself.). Multiply that by your cross sectional area and the density of your air in you area in kilograms per cubed meter (usually 1.225kg/m^3 for an average number) and then divide that into half.
Now take your force in newtons and divide that into the number you just figured out above.
You should now have your coefficient of drag.
Old 03-20-2021, 12:39 AM   #6 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
I almost bought a Dasher because of you freebeard. Seller had already started parting it out by the time I decided to contact him though.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
The Following User Says Thank You to M_a_t_t For This Useful Post:
freebeard (03-20-2021)
Old 03-20-2021, 01:05 AM   #7 (permalink)
Pardon me, but I think I made a mistake. Take the force in Newtons and multiply that by two. Then take the other number from the velocity squared multiplied by the density of air and the crossectional area, but don't divide into two. Then divide the newtons doubled into that number to get coefficient of drag.
The Following User Says Thank You to Isaac Zachary For This Useful Post:
somerandomguy (03-20-2021)
Old 03-20-2021, 01:40 AM   #8 (permalink)
M_a_t_t -- [If I might ask] what was he asking?
Else one could put the car on a tow rope with a GoPro strapped to a spring scale, and measure it directly.
Old 03-20-2021, 09:38 PM   #9 (permalink)
So lets say it takes 3 seconds to go fron 60 mph to 55 mph then what would i do?
Old 03-20-2021, 09:48 PM   #10 (permalink)
Multiply 3 seconds (s) times 2.235 meters per second (m/s) to get 6.705 meters per second per second (m/s^2). Multiply that by kilograms mass of your vehicle (don't forget to include your own mass).
The resulting answer will be force in newtons (N) at around 25.7m/s.
