Old 03-10-2009, 10:16 AM   #1 (permalink)
Iwishthiswasamanual - '98 Ford Escort ZX2
90 day: 32.95 mpg (US)
Photoshop help
I'm pretty sure I've seen a few of you do this here... so maybe you can help.
I want to make a template for side skirts and air dam. I have access to a cad cutter, so i can make paper templates easily.
How do I use photoshop to figure out dimensions of objects?
I know I need to have like a ruler in the image so I can base every measurement on that. But I'm not sure after that.
Thanks,
Zach
Old 03-10-2009, 10:27 AM   #2 (permalink)
90 day: 51.82 mpg (US)
You don't necessarily need to put a ruler in the image; you just need to know the measurement of something of the image.
Then you find the measurement of that item in pixels with the ruler tool, or the select tool (with the "info" window open), and do the math.
EG. let's say your door handle is actually 15 cm across, and in the image it's 90 pixels wide. Pixels per cm = 90/15 = 6.
Is that what you were after?
Old 03-10-2009, 12:52 PM   #3 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
You say you have a cad cutter, so I would assume you have cad as well? If so, maybe it will let you import the file (at least Autocad does). Then you can scale the image to a known length, preferably a large part of the car since that will increase your accuracy. From there you can draw your ideas on it. I do this a lot.
Winter daily driver, parked most days right now
Summer daily driver
Old 03-10-2009, 02:21 PM   #4 (permalink)
It's a vinyl cad cutter. So we use illustrator to make vector images.
Isn't there something that you can say , x pixels = x cm, and when you use the measure tool it states the measurement?
I mean, I guess the way Metro explained it that will work.
Old 04-10-2009, 07:41 AM   #5 (permalink)
Try and look for the information regarding photo shop online and you can even download the tutorials regarding it.
Cheap Xanax
Photoshop fun: GM Volt with racing disc wheel covers (and fender skirts.. and more!) MetroMPG Aerodynamics 30 10-28-2017 06:24 PM
Photoshop please Johnsauce Aerodynamics 10 12-18-2008 11:24 PM
Some nice Photoshop pics of aeromods from a Ford Taurus forum MetroMPG Aerodynamics 11 10-09-2008 03:16 AM
Got any photoshop pics of your car? Sean T. Aerodynamics 7 10-08-2008 02:29 AM
Photoshop for Designing Mods Who The Lounge 0 02-29-2008 03:51 PM
