How did you attach your smooth hub cap cover ??
I'm trying to get some ideas on attaching a pizza pan to my 15" steel wheels on a 99 Saturn SL2. I really want to securely attach the pizza pan and stuff some foam or sponge around the outer rim to reduce vibration. Do you guys have any pictures or ideas.
I've seen the screw-on type (video), Concrete's S-10 setup, and coroplast setup (forgot the user with the Outback with front air dam and wheel covers). Thanks |
Also, seen ModMonster's coroplast setup with tie wraps. I like this but will need to go find a sign shop in metro Detroit.
sl2eggplant -
This is one option for you : http://ecomodder.com/forum/showthrea...isk-11838.html If you want, I will publish the dirty details of the nuts and bolts "shish-ka-bob" fastener system later tonight. CarloSW2 |
Thanks CFG. I'm trying to get parts from local stores only and so far have not found any plastic dishes that match.
I noticed that you're using 91 octane gas. Does that help your Saturn get more mpg? |
sl2eggplant -
Because I have an HAI, I do the 91 octane as insurance against knocking/pinging. CarloSW2 |
My HAI has reached around 225 F (I wasn't looking) and there was no pinging of any kind. Currently, IAT temps are around 150 - 180 F when ambient is around 65 - 85 F. When it gets higher than that, I turn on my little computer fan to mix the air and temps drop to 140 - 150 F.
Forgot, I stick to the cheap 87 octane gas. |
sl2eggplant -
Thanks for the info. I think I'll reduce the octane on the next fill-up and see how it goes. CarloSW2 |
I'm wondering about an equilateral triangle frame made from threaded rods that have turnbuckles to fasten it to the rim by "expanding" the rods; and then have 3 nuts attached (tack welded) to the frame, and use short bolts to fasten the hubcap to the frame, using the nuts.
So it would be kinda' like the clear "racing" disks, but rather than have a round frame that expands to tighten it -- it would use straight pieces to form a triangle frame instead. |
sl2eggplant -
CarloSW2 |
