EcoModder.com
-   Off-Topic Tech (https://ecomodder.com/forum/off-topic-tech.html)
-   -   how do you fill up (https://ecomodder.com/forum/showthread.php/how-do-you-fill-up-18516.html)
drv2die 08-15-2011 01:51 PM
how do you fill up
sitting here reading along happily and thought i havent seen a thread on how you fill your tank. do you pump it until it is in the filler neck stop at the click, round up . shake the nozzle for every last drop?
my car you are suppose to stop at the click if you fill it into the neck the extra will run down the canister vent and into the canister where it ruins it. so i stop at the click and then give a couple of shakes to make sure i got everything i paid for. is there a method that could lead me to easier calculations?
Angmaar 08-15-2011 02:05 PM
I pump it until it clicks then add another "click" of fuel.
gone-ot 08-15-2011 02:47 PM
http://ecomodder.com/forum/165549-post4.html
moorecomp 08-15-2011 03:34 PM
I use the second notch on the handle to keep the fuel flowing (not the fastest setting). I fill till it clicks off, let it settle a while, fill slow till it clicks again and then round to the nearest 10 cents.
CigaR007 08-15-2011 03:52 PM
I stop after the 1st click followed by a 90 degrees rotation of the nozzle to the left and right.
gone-ot 08-15-2011 04:04 PM
...a "twister" not a "shaker"?
UFO 08-15-2011 05:10 PM
My tank filler is vertical. I've removed the tank expansion vent (my tank is vented as its a diesel), so I fill the tank until the level is three inches from the top.
CigaR007 08-15-2011 06:17 PM
...in this case, yes..
Otherwise, no.. :D
gone-ot 08-15-2011 08:48 PM
...as James Bond would say: "...shaken, not stirred..!"
dcb 08-15-2011 09:57 PM
first click, usually same pump, handle vertical and fully inserted.
