EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   How far from the windshield can the driver properly see? (https://ecomodder.com/forum/showthread.php/how-far-windshield-can-driver-properly-see-38643.html)
sgtlethargic 10-04-2020 08:20 PM
I vaguely remember seeing some discussion about this, years ago. How far from the windshield can the driver properly see?
JulianEdgar 10-05-2020 01:15 AM
I don't understand what you are asking.
freebeard 10-05-2020 01:37 AM
Depends on the driver. Depends on the windshield.
You might mean distance from the driver to the windshield. Arm's reach so you can wipe condensation off the inside.
You might mean distance from the windshield to the horizon. The angle of the glass is important. Too steep and refraction obscures the view. Too curved and it displaces objects.
Optimum is the curved-screen Superbeetle. :)
edit: I'm half serious. Compare with the Type III. The Beetle has an A-pillar that's narrower than the B-pillar. The upper corners are rounded. It's like a sliced-off teardrop. The flat screen is best for optical clarity.
JulianEdgar 10-05-2020 02:05 AM
I have a book on aircraft design that, I think, has a section on seating versus windscreen view. But I need more info before I go and dig it out.
sgtlethargic 10-05-2020 01:18 PM
Thanks for the replies, but nevermind- I've decided not to pursue this particular path.
freebeard 10-05-2020 02:37 PM
I guess now we will never know what it was you were asking.
Frank Lee 10-05-2020 04:13 PM
FWIW I don't like the distance to the windshield in the old "Dustbuster" GM vans. I'd consider that, or somewhat less, as my limit.
sgtlethargic 10-05-2020 04:30 PM
What's not clear?
freebeard 10-05-2020 04:58 PM
Nevermind. ....I guess.
sgtlethargic 10-05-2020 07:47 PM
To build something resembling the AST would require a fully cab-forward configuration. I would want to have a front crumple zone there, so I'd want to have the pilot's seat well back from the front bumper, therefore windshield, also. That's why I asked. I'm thinking I won't build a cab-forward car because it complicates engine location, also. And that came about because I just came across a different design that I want to mimick.
