Old 11-27-2008, 06:45 PM   #11 (permalink)
Cd
Ultimate Fail
Cd's Avatar
One of the reasons that a soft top would be easier to do is the fit and finish problem.
It wouldn't be that out of place ( if it was not "perfect" ) compared to some of the soft tops that I have seen on some Miatas and other convertibles.
Old 11-27-2008, 07:50 PM   #12 (permalink)
Silver Turtle - '02 Ford Focus Zx3
90 day: 38.83 mpg (US)
Originally Posted by Cd View Post
LunarHighway : Wow ! I love how the curve of the window echos the curve of the scoop below it. Style !
Well done !
I'm really liking the look of that hard top !
As far as a down turned spoiler, the idea is that you want the airflow to follow the ideal shape as long as possible. By having a flat of upturned spoiler, you are kicking the airstream out of the ideal downward angle.
( But that is just my un-educated guess. )
Yea but I dont know if that window is plausible Ill have to look into it or add a little window to get that curve because the stock window is not like that...
Well the downward angle would work IF the airflow stays attatched... I dont know if the angle of the top is to steep for it to stay attatched though...
Just like in the hatchbacks that I have seen here, most spoilers they use are straight not downward...
Old 11-27-2008, 08:00 PM   #13 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
The Honda CRX was a good example of a well-angled rear window that flattened out just before the back end. Without that detail, the flat back and wake could have been a bit smaller, but it wasn't done for styling, but in order to trip the air into a single large vortex instead of many smaller, random ones.
The best angle for the back window depends on how clean the shape is ahead of it. Turbulent air will follow a more abrupt shape.
Old 11-28-2008, 02:17 AM   #14 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
i've recently compared some profiles in low drag cars 0.29 and lower and it seems most of these cars have a roof angle between 15 and 16 degrees
here's a drawing of the testing i did i just traced a profile drawing of the car and added some lines for measurement
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 11-28-2008, 11:09 AM   #15 (permalink)
Hmmm so the slope of those hardtop photoshops should be alright... I also noticed how most of those have a straight edge at the end instead of continuing downward...
Should be for a reason right?!
Old 11-28-2008, 11:34 AM   #16 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
my guess would be either style or stability.
convertible, hardtop, toyota mr2
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
CRV Cross Country Trip Aero - Temporary Aero Just for the Trip walteraxe Aerodynamics 26 01-05-2010 11:37 AM
has any one ever tried this? how hard is it? Make your own ethanol izanti EcoModding Central 10 12-04-2008 09:41 PM
How-to coat insulation foam to make it stronger? NoCO2 DIY / How-to 18 06-17-2008 09:47 PM
Another Autospeed aero article: methods for measuring aero drag Daox Aerodynamics 4 02-14-2008 12:34 AM
