Old 07-19-2012, 01:49 PM   #11 (permalink)
Put speakers in first, the man has his priorities.
Old 07-19-2012, 02:04 PM   #12 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
if your cats are plugged up itll start blowing the vacuum lines off the egr valve
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 07-19-2012, 05:25 PM   #13 (permalink)
Saturn Freak
Freddy - '95 Saturn SL2
Team Saturn
90 day: 34.25 mpg (US)
Burning oil says you're due for new valve seals and piston rings. It's an involved process, but if you've got a garage and a spare car you can drive for a while, not as bad as many people think. You'll definitely see gains from the improved compression when you replace your piston rings.
