Old 12-29-2008, 08:55 AM   #1 (permalink)
Tracy - '00 vauxhall corsa
how is lean fuel ratio good for FE ?
hi
i have read on this forum that most fuel saving gadgets that claim to improve completeness of combustion are BS because the combustion is already 97% efficient. therefore, how does using a lean fuel mixture make better fuel efficiency?
i'm thinking of going for a wide band lambda sensor mainly because my current one is broken and needs replacing anyway.
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
Old 12-29-2008, 05:28 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
modmonster -
Originally Posted by modmonster View Post
hi
My best understanding is that lean fuel mixtures lead to higher NOx emissions.
Going lean under high-load (performance) driving conditions is bad because it can burn your valves and/or melt your pistons. I call this the Christmas Story Mom retort :
Ralphie: I want my go-cart to run lean!
Mom: You'll burn your valves out!
Under low-load (hypermiling) driving techniques, you can drive lean. This means consuming less fuel. The problem with this is that NOx emissions are increased. Your catalytic converter is *designed* to process exhaust at the 14.7 stoichiometric ratio because that is the sweet-spot for clean emissions and healthy engine performance.
The Fifth generation (1992-1995) Honda Civic VX hatchback and the Honda Insight both have "lean-burn" modes under freeway low-load steady-state driving conditions.
My car has a narrow-band sensor. If I was starting from scratch, I would probably invest in a wide-band sensor/fuel controller (0-5 volt) with enough "support gizmos" to report narrow-band (0-1 volt) signals to my ECU/PCM. Here is an example :
A'PEXi U.S.A. - AFC-neo
The AFC NEO marks the newest edition to the world famous Super AFC line of piggy back fuel controllers. Building upon the powerful SAFC II, the AFC NEO has taken piggy back style fuel control to a new level. The AFC NEO boasts an incredible 16 points of user definable fuel correction. VTEC control has also been incorporated for Honda/Acura applications. A complete monitor mode is also available to keep the driver/tuner informed of critical engine data.
It's very $$, but it's like getting a Scanguage and a fuel controller all in one.
CarloSW2
American Solar Energy Society
Old 12-30-2008, 06:34 AM   #3 (permalink)
thats cool. but how is it like a scan gauge? what data does it show and does it need obd2?
Old 12-30-2008, 11:01 AM   #4 (permalink)
The main problem with lean burn is overheating. Perhaps water injection can be used to counter that? To check temperatures, could a cheap thermocouple be installed in a hole carefully drilled in the exhaust manifold?
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 12-30-2008, 06:48 PM   #5 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Water injection IS used to counteract overheating in lean conditions... see turbo/Nitrous motors.
Yes, you can use a thermal sensor to check exhaust temps at each cylinder... but that's 4 more gauges to watch, and averaging the temps won't help you, b/c engines are mass produced - no two combustion chambers are the same.
There are things you can do to make it easier to run lean though, if you're rebuilding your engine... one of which is cleaning the cast marks and sharp edges off the piston faces. Fuel/air mixtures prefer a clean (not shiny, but clean) piston face. Same w/ the combustion chamber... you can clean the combustion chamber/valve faces up if you ever do a head gasket... do not attempt to clean the pistons unless you can take them out of the block though.
"żʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
Old 12-30-2008, 06:53 PM   #6 (permalink)
Oh - OP question...
Lean ratios basically burn less fuel for the same engine speed... often lowering engine power output as well, meaning higher throttle angles, meaning less VE losses.
It's a two-prong gain - Less pumping losses will net you better efficiency, while leaner ratios means you're burning less fuel to go just as fast. (provided you're still making enough power to maintain your speed.)
Honda and several other MFG's have designed GDI engines that will run at a/f ratios of ~60:1... that said, I don't think they're produced en masse as yet, for several "great" reasons, I'm sure.
*GDI - Gasoline Direct Injection... think diesel, but with spark.
Old 12-30-2008, 07:00 PM   #7 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Christ -
Couldn't you put one high-temp sensor in the exhaust? The idea would be to monitor the combined engine exhaust temp under "normal" operating conditions, and then monitor it under lean burn.
If yes, then I think you could use something like this to keep your engine safe (installed using weld-in bung adapter?!?!?) :
(Jaycar Electronics) High Range Adjustable Temperature Switch with LCD
- Measures to an incredible 1200 degrees celsius
- Switch devices on or off at a set temperature
- Digital readout
- Use it to:
Display any car temperature: oil, exhaust gas, coolant, intake air, brakes, etc
Trigger alarms, warning lights, fans, etc, at a selectable temperature.
CarloSW2
Old 12-30-2008, 07:28 PM   #8 (permalink)
Yes and no... you'd have to test very carefully as some engines really DON'T like lean burn conditions.
Also, the average temp, like I said, won't give you an idea of whether or not one cylinder is in danger, which is quite the possibility, due to manufacturing differences. You could technically be at a lean mixture that is best for one cylinder, and deadly for another one, and you wouldn't know that based on a single temp sensor/switch.
If you were testing very carefully, You could use a single switch/sensor to kick on an additional injector or something that would add water/meth to cool down the intake charge, but you'd have to be doing testing in small increments, as you wouldn't get real time data from each cylinder.
Using either way, you still won't be able to detect hot spots, which are a primary concern when considering a/f ratios. (and in general)
Old 12-30-2008, 08:54 PM   #9 (permalink)
Silver Turtle - '02 Ford Focus Zx3
90 day: 38.83 mpg (US)
I am planning on doing this to my car sometime, and I will add a multi firing spark plug module (MSD) so that I can ensure that the flame completley burns.
Other than that, you have to be sure the air and fuel mix THOROUGHLY (aka homogeneous) otherwise you start developing knock.
Old 12-30-2008, 09:29 PM   #10 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Christ -
Thanks. That agrees with something I read recently on saturnfans. A fellow was driving 90 MPH with 93 octane, and he burned a hole in his piston :
Picture of Hole in Piston
This is a response he got from a wise old Saturn Fan :
SaturnFans Forums - View Single Post - What would cause a hole in the piston?
Originally Posted by OldNuc View Post
The #4 cylinder runs hotter than the other 3 due to the EGR. The amount of carbon does not look like a preignition condition from carbon. You were using a high octane fuel so low octane did not cause it. Timing advance due to the higher octane and a defective knock sensor or as postulated a bad injector. A lean condition will usually take the center out of the piston and preignition chews on the edge.
This will help a bit Preignition photo
CarloSW2
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
Hydrogen Generator Experiment willy57 DIY / How-to 601 08-23-2016 05:53 AM
Can't Get Good Fuel Economy - 2008 Civic Manual whatjigg EcoModding Central 44 08-25-2014 06:14 AM
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 09:24 PM
