Old 08-07-2014, 08:35 PM   #131 (permalink)
Joggernot's Avatar
Originally Posted by CapriRacer View Post
Allow me to confirm that there are detail differences in the construction that affect the wear characteristics. That is why I have been arguing that you can't generalize that tires run at elevated pressures don't develop center wear. Some do.
Mine did, to the point of having to replace them with good tread on the edges. Wore the center out similar to riding the m/c on the highway (had "chicken strips"). The tires I now have seem to be wearing evenly. We'll see as the miles accumulate.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
SAE Paper 800087 – The Effect of Inflation Pressure on Bias, Bias-Belted, and Radial CapriRacer Hypermiling / EcoDriver's Ed 18 07-06-2008 06:36 PM
Tires with different max PSI Goldenfrog EcoModding Central 2 06-14-2008 03:42 PM
I upped the PSI to my tires from 29 to 35 and... MartialArtist EcoModding Central 55 04-04-2008 01:20 AM
