EcoModder.com
-   -   How much HP and Torque can a TCC handle??? (https://ecomodder.com/forum/showthread.php/how-much-hp-torque-can-tcc-handle-10098.html)
IsaacCarlson 09-09-2009 05:58 PM
common sense tells me that they would have to be pretty durable to handle what they do for as long as they do. But I still wonder why they unlock at 90% load, is it because the car knows you want more power so it lets the rpm go up?
how much gas can i give it without damaging it in lower gears? part of the reason i ask is because cars don't generate much power at low cruising rpms. Is that why TCC don't lock up all the time in 2nd through...?
dcb 09-09-2009 06:15 PM
A torque converter is able to multiply torque when there is a significant difference between input and output speeds. Torque converter - Wikipedia, the free encyclopedia
at %90 load, maybe they think you want more torque (not always true)?
roflwaffle 09-09-2009 06:51 PM
I think the OP is asking about the lock-up clutch.
dcb 09-09-2009 06:55 PM
if you unlock the torque converter, it can multiply torque, yes, inefficiently.
Frank Lee 09-09-2009 07:11 PM
42.
IsaacCarlson 09-10-2009 12:02 AM
42 what? nt
dcb 09-10-2009 12:26 AM
It is the answer to everything.
http://ecomodder.com/forum/showthrea...und-10073.html
Click on the movie link, it should explain everything :)
Frank Lee 09-10-2009 12:34 AM
I wonder how much wood can a woodchuck chuck-
if a woodchuck could chuck wood?
Is it 42? :confused:
IsaacCarlson 09-10-2009 12:35 AM
must be
Frank Lee 09-10-2009 12:40 AM
Good. Now I will be able to get a good night's sleep.
