Old 05-13-2009, 11:39 AM   #1 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Ford dusts off old ideas, hopes to get 2011 Explorer to 30 mpg.
I found an interesting article about Ford engineers taking a second look at old ideas to boost fuel efficiency. Primarily weight reduction, direct injection, and turbocharging a smaller engine to obtain the same horsepower.
They forgot about aerodynamics.
again.
-Terry
Old 05-13-2009, 12:16 PM   #2 (permalink)
90 day: 51.82 mpg (US)
This article brought to you by the Save The Trucks! foundation.
Old 05-13-2009, 02:23 PM   #3 (permalink)
Deadly Efficient
Ha ha! Yeah, but is it really a truck if it's on a Taurus platform???
-Terry
Old 05-13-2009, 07:59 PM   #4 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
So, it's a unibody minivan styled like an Explorer so people will actually buy it. It's a mild hybrid, turbo four cylinder that gets 30mpg. That's great news! The body-on-frame Explorer is dead.
If only the Fiesta was this big of an improvement over its predecessor.
Old 05-14-2009, 07:31 PM   #5 (permalink)
Realistically DI and throttleless engines are as FE as diesels.
If they jumped those two fences at the same time they'd pop some serious FE gains.
If they do that and run it lean all the time like diesels and use the turbo to create the artificially high AFR it will get closer to diesels. Instead they will use it to maintain HP with lower engine weight. Just give it less go, no throttle body, DI and a turbo to jack AFR.
free OBD2 software with MPG calc whitewiz Instrumentation 11 12-10-2014 10:53 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
2011 Ford Fiesta: An Unexpectedly Impressive Car SVOboy EcoModder Blog Discussion 10 06-11-2009 08:25 AM
Hypermile a Ford Fusion hybrid: average 21 mph over 1446 miles = 81.5 mpg (US) MetroMPG Hybrids 25 05-04-2009 06:34 PM
Video: prototype Ford F-150 plug-in hybrid - 41 mpg MetroMPG Hybrids 2 07-29-2008 12:36 PM
