How to Setup Ecomodder Mileage MPG image in Your Signature
3 Attachment(s)
The current how to thread seems out-dated, so I figured I could make a new/updated one and try to make it a little simpler. Please note, if you have under 5 posts, you won't be able to have the link on your sig, but the image should work fine.
At the top of the site click the Garage link (red box in photo) http://ecomodder.com/forum/attachmen...4&d=1331533431 Click the view button next to your vehical http://ecomodder.com/forum/attachmen...3&d=1331533382 Note down your vehicleid number http://ecomodder.com/forum/attachmen...5&d=1331533442 Go to the User CP and click Edit Signature Copy and Paste the below text and edit the two spots 9999 shows up to what you saved earlier HTML Code:
[url=http://ecomodder.com/forum/em-fuel-log.php?vehicleid=9999] HTML Code:
[img]http://ecomodder.com/forum/fe-graphs/sig9999a.png[/img] Preview it and if it shows up right then save it! This should work for other forum sites that use BBcode as well. |
Short and to the point. I like it. :thumbup:
Thank you ! :)
Glad I have 2/2 approval. |
tryed twice and all i got was invalid file
http://ecomodder.com/forum/fe-graphs/sig5578a.png HTML Code:
[url=http://ecomodder.com/forum/em-fuel-log.php?vehicleid=5578] The 'a' at the end of the sig name is required, and I'm guessing that is what most people will have trouble with. Format is sigXXXXa.png |
ok think i got it. OK it did work, thanks for the help.
is the re a minimum post count? my preview is right but it doesn't show in forum!
I guess I got it!
no matter which way i try to set up my sig, it just gives me an "invalid file" error. I tried with the "a", without it. I tried the old post of how to do this, and the new.
I also noticed there is a space between the [/img] and the [/url] on both examples above. I also tried it both ways still with the same result. |
