Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 01-04-2010, 01:36 AM   #1 (permalink)
Mountain bike guys say they're faster with LOW tire pressure
15 WAYS TO IMPROVE THE TUBELESS EXPERIENCE | News | Mountain Bike Action mountain bike, mtb, mountain bike racing, freeride, Downhill MTB, bike tests, MBA, Mountain Bike Action, Ask RC, XC mountain bike, trek, specialized, giant bikes, mantis, ellswo
Old 01-04-2010, 02:07 AM   #2 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Reading further into it, there's a good reason... they're saying that the higher pressure makes the tire more susceptible to bouncing up and away from bumps in the road, so useless spinning of the tire occurs.
This isn't such a concern on, say, cars, where there is alot more weight per unit area of contact patch of the tire.
Old 01-04-2010, 03:03 AM   #3 (permalink)
I don't have numbers right now but I suspect the loading i.e. psi in the contact patches would be quite similar...
Old 01-04-2010, 04:35 AM   #4 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Frank Lee -
It seems like this would apply to off-road driving conditions. Would the same article be applicable for Tour de France?
CarloSW2
American Solar Energy Society
Old 01-04-2010, 05:20 AM   #5 (permalink)
Further investigation required!
Old 01-04-2010, 06:03 AM   #6 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
I've had a few mountain bikes and i do agree that higher pressures made traction worse. But i also agree that a mountain bike tire and a car tire are two very different animals. Also the conditions are very different......usually!
ollie
Old 01-04-2010, 06:57 AM   #7 (permalink)
Maroon Ballon - '98 Chrysler Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Geo Metro 5spd hatch, 3 cyl
Not again...
I dropped out of the last tire argument because some really ridiculous things were said in a very contentious manner, and my words were twisted into things I clearly didn't say. I didn't check back, but I doubt that anything was resolved.
You can bring random facts to the fore, but you can't make any of these anomalies apply to a real world FE argument.
For instance. when a top-fuel dragster approaches the start line, the tire appears to be very low on air. It's squat to the ground, and you can see the stress in the sidewall. But when the light goes green the centrifugal force of the spinning tire sends the tread to the outside very forcefully, and the car seems to jump in the air as it moves very quickly for a quarter mile. To apply any of this to hypermiling your daily commute just won't work.
The race conditions of the Tour de France and the Leadville 100 are very different from each other, but Lance Armstrong has won both. The latter on a flat tire.
http://www.singletracks.com/blog/mtb...lle-trail-100/
In a bicycle road race you do need traction, but the object is more one of as little RR as possible, and this is achieved by tire pressures well above 100lbs, resulting in a very tiny contact patch.
In a mountain bike race this would never work. The tires are knobby, not smooth, much fatter than road tires, and operating with much lower pressure.
So dragsters win races on tires that appear to be flat at the start line. Lance Armstrong wins the Tour de France on tires pumped up to 120-150lbs per square inch, and also wins the Leadville 100 on a rear tire that had maybe 2-3lbs in it. All interesting facts, but applying these facts to your daily commute to benefit your fuel economy will be even more interesting.
Old 01-04-2010, 08:18 AM   #8 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
I've raced with tubes and with Stans tubless. We ran at 45+ psi just like everybody else. No wonder I sucked.
There was a noticeable increase in rolling resistance with the same tire at 25 PSI then at 50 PSI. The big advantage was in flat protection and weight. You could take lines that were not available with tubed tires and the Stan were a little lighter which makes a big difference. I think this is like EPA testing. It's great in the lab but does not translate to real world mountain bike racing. If you look at most MTB race course there not real technical and mix in a lot of hard pack and jeep trails with a few rocky technical spots to keep it interesting. Depending on design of the tire, fat 2.0 vs skinny 1.85, at the end of the day usually the higher the PSI the faster. YMMV
"Judge a person by their questions rather than their answers."
Old 01-04-2010, 08:08 PM   #9 (permalink)
epic stock master
luvit's Avatar
86 Accord LX (carb) - '86 Honda Accord LX
90 day: 35.57 mpg (US)
do these bikes have those stupid metal bars down the middle?!?
single person car thread
Old 01-04-2010, 09:29 PM   #10 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
offroad/low traffic concern, if you drive on riprap a lot then worth considering. if mostly relatively smooth pavement then you want inflated tires for efficiencies sake.
washboards are probably a more common case, but even then it is maybe %0.0000001 of the average vehicles miles (total swag).
A psi vs/"planing speed" test for washboards might be interesting to look at too, if anyone has a washboard nearby and is bored.
I've done the pedal low tires on pavement investigation, it arent efficient.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
Valve stem caps that blink when your pressure is low SVOboy EcoModding Central 1 12-23-2007 03:57 PM
