Go Back   EcoModder Forum > AltModding > Saving@Home
Old 01-07-2023, 10:25 AM   #21 (permalink)
Like I said earlier there are aftermarket remote controlled dampers, some which install without taking apart the duct. I just like the balloon ones that install through a hole in this duct
The Following 2 Users Say Thank You to Piotrsko For This Useful Post:
hayden55 (01-08-2023), redpoint5 (01-07-2023)
Old 02-04-2023, 02:22 AM   #22 (permalink)
90 day: 28.24 mpg (US)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 24.55 mpg (US)
Attic humidity has remained about 80%, which concerns me. There's no way the dinky and sparse 2" circular soffit vents allow enough air in. Not only do they have vanes, but also screens, with a UPC sticker covering most of it. I know outdoor humidity has mostly been well under 80%, especially when it's below freezing.
Attic
Basement
EDIT: I just realized my iPhone emails photos in PNG format, which is pretty inefficient. Yes, I email photos from my phone because iPhone has no method of transferring files easily unless you install iTunes.
ID:	33317   Click image for larger version
Old 02-04-2023, 09:55 AM   #23 (permalink)
Isn't RH dependent on temperature? You have all this nice warm 56% RH air entering the attic from the ceiling with no vapor barrier hitting a cold attic.
Old 02-05-2023, 02:37 PM   #24 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
Sequoia - '04 Toyota Sequoia Limited
90 day: 17.51 mpg (US)
Yeah I would agree. RH doesn't mean much in the attic. You just want to compare it to outside of the attic and see that it is pretty much about the same as it means it is capable of drying itself (as long as it isn't leaking or moldy up there). A lot of the times your walls and ceilings and ducts will sweat depending on what you're doing because they will hit dew point on the cold outside surfaces. When I say that i just mean a cold surface will condense water out of the air onto it. So more or less the walls just dry through and keep chugging to a certain point (range of 30-60% inside is pretty good for that). Inside though is really where the humidity and dew point matters. Things really start to hit dew point on exterior surfaces when you get high humidity inside which will lead to wet moldy walls etc...
You can see the dew point, wet surface, mold thing really well on windows typically as they aren't able to dry through and have very little insulation so they are always a cold surface in the winter for water to condense on.
Like I said as well about drying through I can take an hour shower since I haven't fixed the bathroom vent yet and go in the attic and you can see the moisture in the loose fill fiberglass. Its not much though and it drys through so theres no mold.
Redpoint I would say paint the basement with a good epoxy waterproofer, insulate it with foam board or fiberglass whatever your heart desires, play with a top vs bottom damper in your duct, maybe even try a radiant barrier up top on the rafters and play with your venting in the attic for temp reduction and see how it goes. That should reduce the heat gain a bit in the top and replace the air more often so it stays closer to thermostat temp up there, and insulating the basement will get rid of the ground cooling effect down there. Should bring them closer in heating and cooling loads but probably won't be perfect. The hvac system might be able to manage it though!
Also, air sealing with a foam gun and caulk will help you a bit as it sounded like your hvac was unable to keep up sometimes. Less air changes means less outside air coming in needing to be conditioned.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
redpoint5 (02-05-2023)
