01-01-2022, 01:35 AM
aero guerrilla
External battery starter assist
For those who go alternator-less:
What about having a second starter battery in your garage, which you connect parallel to the car's battery whenever you park at home. The initial start up of the engine would halve the current need and halve the power drain on the car's battery, leaving a bit more for your trip. Both may also slightly reduce wear/aging of the battery, increasing its useable life.
01-01-2022, 10:33 PM
Too many cars
I wouldn't bother unless my battery was barely able to make the trip. And then I'd probably just upgrade the onboard battery. Which is exactly what I did with my old Honda Civic. I had two oversized batteries in it and never had any issues, even driving around all day.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
01-01-2022, 11:05 PM
0.25 watt hours on a 600 watt hour battery isn't much to be concerned over.
01-01-2022, 11:06 PM
マット
You could also push start it.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
01-01-2022, 11:22 PM
Big mainspring on the pulley end. Automatic rewind, with a handcrank assist.
01-02-2022, 09:25 AM
While in the garage, you could also crank the car with the charger still attached.
01-02-2022, 09:47 AM
Throw some capacitors in parallel with the battery to carry around with you, perhaps?
01-02-2022, 03:35 PM
aero guerrilla
One of the reasons for this idea is to reduce weight.
But as @redpoint5 calculated, the savings are not much.
Not worth actually doing, but just a thought experiment.
01-02-2022, 04:36 PM
#9 (permalink)
Too many cars
That's what's keeping me from putting the oversized batteries from my Civic into my Insight. They're so heavy!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
01-02-2022, 04:57 PM
#10 (permalink)
In flight of the Phoenix they used shotgun shells.
