Hydrogen Cell / Hydrogen Generation
I am hoping that someone here can shed some light on my concerns and perhaps set my logic straight on this matter.
Long ago, I learned that the Earth has a fixed amount of water in various states; Liquid, gas & solid. With that said, the Earth cannot run out of water, simply continue to change its state. Now It is also my understanding that Hydrogen fuel cells have water as a by product. Is this because of a complex HHO conversion or are we literally producing water? If we are producing water and this technology flourishes, then I see a problem. Supplying extra water to the Earth. Which could lead to global warming, elevated sea levels and increased humidity. Ami I completely wrong in thinking this way, or what? |
I think you answered your own question. Water just changes state.
An HHO setup takes distilled water and converts it to H2 and O. The engine burns these gasses with the result being water. The water then exits your cars tail pipe. There is no creation of more water because you started with the same water. |
That is correct for HHO, however what are Hydrogen Cell vehicles? I saw in a commercial that a hydrogen cell car produces water as its by-product, what do you know of those?
A hydrogen fuel cell combines hydrogen and oxygen to make electricity (to drive an electric motor). Its byproduct is also water.
trikkonceptz -
The local "microclimate", however is another matter. I do have this running "what if" joke. What if all the cars in Los Angeles were suddenly fuel cell vehicles? My guess is that the humidity would shoot up and maybe we'd have lot's of "June Gloom" foggy dayzzzz, ala San Francisco. Mayyyyyybeeeeee all the rain in BladeRunner is just a byproduct of fuel cells!!!!!! : http://home.cogeco.ca/~blade2019/images/spinner02.jpg See all that white smoke!?!?!?!? I say that's steam!!!!!!!!!!!!! CarloSW2 |
I see what you are asking. I remember reading that much of the commercial hydrogen is derived from methane/natural gas. This does not seem to be different then any other hydro-carbon so when used in a fuel cell it still combines with oxygen producing water. Oxygen is pulled from the air just like an ICE would burn hydrogen so the equation is the same as petrol but cleaner.
I doesn't seem like too big of a concern though. It seems nature has built in negative feedback loops like if CO2 or water vapor levels get too high then plant life will flourish to take more of it out of the air. |
I cant really answer the first question because i dont know. I know HHO is not a problem , you take water split it burn it then it recombines to form water again. i will have to get on google. |
