Old 11-11-2009, 02:58 PM   #1 (permalink)
Insulating air intake?
The air intake on my crossover SUV started under the battery, sucking in hot air from the engine compartment. So with some flexible tubing from Lowe's, I extended the intake to a fog-light opening under the bumper, for a ram-air effect. One auto accessory company sells an insulated "wrap" to keep the air in the intake system as cold as possible, but I could probably find similar (and cheaper) material at Lowe's. So here is the question: Is it worth the time and effort to insulate the new intake tube and/or the the existing air filter box?
Old 11-11-2009, 05:11 PM   #2 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
You'll probably find most people here have hot air intakes and if they have insulated their intakes, it's to hold the heat in!
But if you are after power then it will help a little i guess. Measurable? Maybe!
ollie
Old 11-11-2009, 07:25 PM   #3 (permalink)
So hot air increases fuel efficiency and cold air increases power....correct?
Old 11-11-2009, 07:50 PM   #4 (permalink)
Draco - '89 Ford F150 ext cab shrt bed XLT Lariat
90 day: 16.45 mpg (US)
Yes, Hot air isn't as dense so it requires less fuel to achieve the proper air to fuel ratio. Plus i think it helps atomize the a/f mixture.
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
start to play with IAT sensor on Mercedes E250D-Turbo 98' poisas EcoModding Central 6 10-07-2013 04:13 PM
Hot Air intake vs. Cold Air... why or why not? Blister General Efficiency Discussion 3 10-09-2008 10:01 AM
Grill block affected milleage mar5ka Aerodynamics 24 08-31-2008 10:17 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
