Old 08-01-2008, 07:23 PM   #1 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
I learned a way to keep car interior cooler
As some know, I went beyond tinkering with a 20 year old subaru and the worlds most efficent four cylinder design, by welding, actually adding weight, adding aluminum, and steel where necessary...and worked fuel back up into high 30s even wtih snow treads on (rally type tire- it is a subaru).
An epiphany upon undercoating a simple two inch wide strip of rocker panel...approx 6 feet on my wagon..
I turn the vent blower on cool and it was actually cool on a hot day. It has always been warm.Thought nothing of it, until it did it again after sitting all day in hot humid sun.
Underside creates the interior temp? I thought since then of a few other unibody channels that I will treat, even tho the factory did not treat it, worth a mention. Alot of cheapskate in auto manufacturing. I am glad to doubt it all, one thing at a time, even unplanned findings. this was just another one.
I also noted that .25 inch foam panel will fit under the rather solid roof liner, even though I have not felt warmth from there, it only shows that the cool inner body channel's go to the roof as well, one large sneaky hidden system, and it is for more than acoustics, but thermal comfort.
Old 08-01-2008, 07:27 PM   #2 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
No way - really?
Where do you think might be good places to add insulation in my truck? It's never had air, so anything that could reduce the interior temp can't be a bad thing.
I even tried piling ice onto the cowl vent once; no effect.
Old 08-02-2008, 12:24 AM   #3 (permalink)
Red
Red's Avatar
I know there is a big difference cabin temperature if you insulate the floor pan on a Jeep. What material did you use?
Old 08-02-2008, 08:27 AM   #4 (permalink)
38 time NHRA/IHRA Champ
ATaylorRacing's Avatar
Or you could go to Roshgo Corporation
they have a plug in fan that goes in place of a Igloo 25 qt or Coleman 28 qt cooler lid. It draws air in from one end....over the ice.....the blows it out the other end at about 50 degrees. I ordered one for my Geo and will take it to the race track to put in my car between runs!
42 time NHRA/IHRA drag race champ
05 SRT4-12.17@117 mph on DOTs-31.0 mpg-SOLD
96 Geo Metro-3 banger-60.1 mpg-SOLD
95 BMW M3-13.41 @ 106 mph-31mpg-SOLD
77 Chevy Monza with 350/350-FOR SALE
84 Horizon-1880 lbs-29 mpg
95 Neon-43 mpg
99 Z28-10.80 @ 127 mph-27.1mpg
2011 Prius-62.1 wife's
Old 08-02-2008, 10:44 AM   #5 (permalink)
TheDon's Avatar
Pepper - '87 Mercedes Benz 300D
90 day: 30.42 mpg (US)
a swamp cooler?
a/c helper
I found another advantage to driving an ultra-low Cd car basjoos Aerodynamics 26 08-25-2012 02:15 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
My First Electric car Experience WaxyChicken The Lounge 8 09-05-2008 08:46 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
