Old 07-17-2020, 04:43 PM   #11 (permalink)
Originally Posted by GreenTDI View Post
What is your tire pressure?
1,9 bar in the front, 2,1 bar in the rear, like required. I like comfortable riding.
Old 07-18-2020, 04:14 AM   #12 (permalink)
I just tried P & G, plus engine switch off, and my decision ist: From a holistic consideration, I just donīt want to do this. It clearly destroys my pleasure of driving (smootly and seamless running engine), as for example slipstream driving also do. Also I think, that the expends of replacing starter will reduce my moey saving. Iīm not looking for fuel cost reducing at all costs, but thanks nevertheless for the advices!
The Following User Says Thank You to Silent Blood For This Useful Post:
tshire (06-26-2021)
Old 08-09-2022, 05:32 AM   #13 (permalink)
Hello, I've had a 528i auto touring, and it was sensible to tire pressures. I always use pressure above 2.3. The touring being heavier (factory spec) states 2.7 in the rear axle when loaded. I used 2.4 in the winter/rainy weather and higher when sunny. I got 12lt/100km on LPG (highway driving auto gearbox cruising 90km/h). Added benefit of higher tire pressures is better manouvering when stationary or slower speeds. If you're in Germany, I would try some grill block when cold.
