05-11-2023, 05:47 PM
Ultimate Fail
How does heat affect air flow around exhaust ?
Just as the title asks, how does heat coming from hot engine exhaust affect the cool oncoming air ?
( I'm thinking of how that air reacts in clouds when cool air meets warm air. )
From what I understand ( or don't ! ) the air creates a vortex.
05-11-2023, 09:38 PM
Intuitively I suspect if airflow was originally laminar, it would increase drag, if not, it might reduce drag. I'm only guessing waiting for those above my paygrade to respond.
The Following User Says Thank You to j-c-c For This Useful Post:
05-11-2023, 10:59 PM
Myself also.
Whatever the effect it's probably minimal for an exhaust buried in the underbody. The edge cases would include side pipes at the rocker panel and vertical stacks on a truck.
I gave it my best shot in 2014. Here's vertical stacks with a Coanda nozzle the full height. Because why not?
.tragectory: Line goes down and to the right.
05-13-2023, 08:06 PM
Ultimate Fail
Myself also.
(Was a picture attached ? I'm not seeing one.)
The Following User Says Thank You to Cd For This Useful Post:
05-13-2023, 08:19 PM
There spozta wuz....
Really more suited to a canopy or camper. But there's a single-wheel trailer and half-tonneau as well.
05-15-2023, 11:28 AM
'exhaust heat / vortex '
Considering that cars can be front-engine, inline, transverse, mid-engine, rear-engine; have fully-wrapped exhaust systems, fully-exposed exhaust systems, etc., you might want to choose a specific vehicle that we could think about.
The 'meteorological ' vortex phenomena require special conditions, usually constrained by convective-available-potential-energy ( CAPE ) along the squall line ( recently 1,300-miles in length ), which limits the warm, moist, equatorial 'Gulf' air's buoyancy and ability to penetrate the cold inversion layer aloft, tapping into 33,000' - 47,000' sub-freezing temperature, high-density air, which is part of supercell dynamics, along with opposing shear winds around 10,000-feet, which create the 'couplet' which aids the ant-cyclonic circulation which will lower to the ground in a wall cloud as the vortex.
All this begins at the poles, with the polar vortex.
05-15-2023, 01:26 PM
Now there is a 'big' picture' approach.
https://whitney.org › exhibitions › buckminster-fuller
Buckminster Fuller: Starting with the Universe | Whitney Museum of ...
One of the great American visionaries of the twentieth century, R. Buckminster Fuller (1895-1983) endeavored to see what he, a single individual, might do to benefit the largest segment of humanity while consuming the minimum of the earth's resources. Doing "more with less" was Fuller's credo.
You start with Universe and discard anything at too large or too small a scale; which involves discernment.
