Old 12-03-2008, 03:24 PM   #11 (permalink)
Originally Posted by dichotomous
the holes in the grill might even allow enough air to pass through to make it a smaller brick aerodynamically
Nope.
Why not? The grill is big and flat, and has huge holes in it. It looks like maybe the Jeep was designed for a lot of flow through the grill, past the motor, and out the bottom of the engine compartment and/or the wheel wells. So blocking the grill would stop that flow, resulting in a big high pressure area sitting in front of a planar surface, which could result in more drag. It isn't like a passenger car, where the grill is smaller, and the front of the car more aerodynamic to start with.
Old 12-03-2008, 03:31 PM   #12 (permalink)
dichotomous's Avatar
CivySi - '03 honda civic SI
90 day: 31.99 mpg (US)
you could try using a flat angled sheet of plastic from the front edge of the bumper to the top of the grill, maybe clear plastic and youd get you headlights to shine through. also smooth out and fill in the gap between the bumper and wheel wells, throw an airdam on there that covers the front wheels as much as possible, and if you have skinney tires and flares, 4 wheel skirting would help.
though, I dont know how much all that would do. your biggest problems are the engine and drivetrain, neither are efficient at ALL, but then again they are rugged and tough
Old 02-07-2009, 01:44 PM   #13 (permalink)
I think people on this forum put too much stock in grill blocks. They think that because the air going through the radiator and engine bay is turbulent, having the airflow slam into even a vertical surface is somehow better. I think if anyone here had a jet engine, they'd try to block the intake "because flow through a jet engine is turbulent".
A grill block may improve aerodynamics on some vehicles, but on a Wrangler, airflow is gonna hit that grill block, and fan out.
To see what I'm talking about, hold a knife horizontally under a running tap. Now hold a fork under the running tap to simulate a grill.
Old 02-07-2009, 01:49 PM   #14 (permalink)
You should try an angled air deflector attached to the bumper. You can extend it downwoard to deflect flow under the front axle, and attach a bellypan to the crossmember to deflect air under the rear axle
Old 02-10-2009, 05:16 AM   #15 (permalink)
Red Egg - '95 Ford Aspire
90 day: 38.51 mpg (US)
Dodge SRT-4 - '04 Dodge Neon SRT-4 2.4L Turbo
90 day: 26.24 mpg (US)
a vehicle has to already have some aero properties to benefit from a grill block. sealing the front up helps its aero. with a brick all you are doing is blocking radiator. Helps it reach operating temps faster. Its not doing alot of diverting air. You'd need a nosecone or what others are posting IMO. I would do simple cardboard rad blocking, and also work on sealing up the underside.
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 11:38 PM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 10:22 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-21-2012 12:34 AM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 01:31 AM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 07:54 PM
