Go Back   EcoModder Forum > AltModding > Saving@Home
Old 05-21-2023, 09:12 PM   #1 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
New high efficiency AC designed by morons
Antique cheap ACs have plastic guards that fit (snap) into the window tracks, 5 seconds done.
High efficiency inverter AC to be properly secured requires a useless metal bracket bolted into the center of the window sill.
To center I would have to drill insta crack plastic and bolt in every year, any movement and my sill would likely explode.
I guess no 8-12k btu inverter AC for me, it’s not reasonably possible to install without milling a custom block of wood at an angle that I would need to install and remove every year, or place blocks, don’t use the bracket and rely on the window to bear the weight, fail all around
Old 05-22-2023, 06:52 PM   #2 (permalink)
Unfortunately most new tech has not been made retrofit-friendly...
