Old 10-14-2012, 08:21 PM   #1 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I hate when this happens
Went an apparent 920 km on 8.2 gallons. I have been running this odometer (yeah it is metric ) for the last 2000 miles. I did switch to a more expensive fuel and found a loose front hub during the last tank.
The car is rolling better.... what ever that means.
69 mpg Next fill in a couple of weeks might confirm or just bring it back to reality. The last time I had a nice bump in mileage happened all at once so I know things happen.
Noah Webster, 1787
Old 10-14-2012, 08:30 PM   #2 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
In the end it all works out. It may make your next tank look bad, but the average of the 2 should be about right.
Is that 1.6L that you have turbo'd or just natually aspirated?
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 10-14-2012, 08:33 PM   #3 (permalink)
Do more with less
Dave,
It is a non intercooled turbo. I obviously drive it at as low of rpm as it seems to tolerate.
I have a new set of injectors but they are still in the box.
I hear you about averages. Looks good today and fairly crappy next time. That is what I hate.
Dave
Noah Webster, 1787
