Old 09-14-2015, 06:10 PM   #1 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Check your brakes
I thought my power-nothing 1989 Toyota Pickup did pretty well coasting, and I consistently returned 30-31mpg driving with moderate EOC in the city. I noticed that whenever I used and released the parking brake it took some time before the coasting ability returned. Turns out the lever in the driver's side rear drum was frozen, causing a shoe to drag all the time. Easy to fix, with DRAMATIC results.
I was at the end of my tank when I fixed the brake. Even so, I got a new high calculated tank mpg of 32. I am still on the first tank since the repair, and it looks to be the best ever mileage with the truck. I always note how many miles when the fuel gauge registers at the 1/2 tank mark, and it typically is between 200-230 miles. With no major changes to how I drive I passed the 1/2 way mark at 300 miles!!
This means I am on track to 40mpg on a tall 4wd pickup. I need to get a sticker to put on it saying "Got 40mpg?"
I'm not coasting, I'm shifting slowly.
The Following 2 Users Say Thank You to UFO For This Useful Post:
MetroMPG (09-14-2015), whatmaycome14 (09-18-2015)
Old 09-14-2015, 06:53 PM   #2 (permalink)
Good idea to check the drum temperatures, just put your hand on one then the other on the outside and see if one is much hotter.
Checked the mechanical brake adjustment on my 37 ford (all cables) with a laser thermometer, hotter, back it off cooler tighten it up. I could stop that car with my thumb.
regards
mech
Old 09-14-2015, 07:44 PM   #3 (permalink)
90 day: 51.82 mpg (US)
Nice! Make sure to come back and update this thread when the tank result is in.
Old 09-14-2015, 09:38 PM   #4 (permalink)
Carbon Abuser
iamnotahippee's Avatar
Olaf - '03 Honda Civic Hybrid
Sven - '06 Volvo Xc90 2.5t
Work Truck - '04 Chevy Silverado 3500
To that end...if there was a way to go 4 wheel drum brakes, that would return the best mpg. Disc brakes are going to drag...period. They relay on the elasticity of a square cut o-ring to open the brakes up when they are released. Keeping all the friction surfaces and the caliper pins cleaned and lubed would be a good preventive maintenance along with checking all the rear drum brake gear.
1986 Chevy C-10 10mpg Grandpa's Truck
2004 Chevy 3500 diesel 10mpg The work Truck
2003 Honda Civic Hybrid 5 spd ?? Mpg My Carbon Pentance
The Following User Says Thank You to iamnotahippee For This Useful Post:
Joggernot (09-15-2015)
Old 09-15-2015, 09:38 AM   #5 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
I'll concede that, all things being equal, disc brakes may have a touch more drag than drum brakes. And performing the maintenance items you mention is an excellent idea as well. But wheel bearings always have a bit of play and brake rotors always have a bit of runout, so brake pads are always going to be pushed back at least a bit from the rotor. Also considering the number and scale of other sources of friction in an automobile, disc brake drag is a pretty minor factor.
Drum brake drag from sticky cables however - I saw a *lot* of that in my mechanic days, and it can be considerable. Also folks should be aware that many cars with 4-wheel discs have separate drum brake assemblies, typically on the rear wheels, just for handbrake duties. Subarus for example have them inside the rear rotors. These tend to be ignored when servicing brakes and can be a source of drag just like a vehicle with rear drum brakes.
Old 09-15-2015, 12:07 PM   #6 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
My Festiva coasted way better than my Insight does, and that car was about the least aerodynamic shape possible. That was because I bought an extra set of disc brake drag reduction clips and doubled up on them, so the disc brakes didn't drag at all on that car.
The Following 2 Users Say Thank You to cowmeat For This Useful Post:
BabyDiesel (10-04-2015), MobilOne (10-06-2015)
Old 09-17-2015, 09:32 PM   #7 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
Really? I don't seem to have TOO much of a problem with THAT with my Mustang or my F-250. I've had MORE problems with eccentric drums.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
Old 09-20-2015, 02:25 PM   #8 (permalink)
UFO
UFO's Avatar
Filled the tank today, entered it in the fuel log. Not as good as projected, but I got a solid 35mpg, 3mpg more than my best ever.
I added this fillup to fuelly.com. I have the highest fuel mileage of any Toyota pickup, including the 2 wheel drive versions, eheheh.
Old 10-04-2015, 12:13 PM   #9 (permalink)
RAV4 - '16 Toyota RAV4 Hybrid Limited
90 day: 35.26 mpg (US)
The rear calipers on my '06 Highlander Hybrid froze shut a couple years back. Fixing that got me 2-3MPG and much longer coasts.
Old 10-05-2015, 10:54 AM   #10 (permalink)
UFO
UFO's Avatar
Yes, I have to say with this brake repair and the manual transmission conversion on my VW, I have an entirely new outlook on how far cars can coast, and I am still recalibrating when to stop applying power.
