Old 02-10-2013, 03:15 AM   #1 (permalink)
Master of 140 hamsters
superchow's Avatar
Hamster - '07 Honda Civic EX
90 day: 29.41 mpg (US)
Whooshy Wagon - '04 Volvo V40
90 day: 23.33 mpg (US)
Minotaur - '09 Ford Taurus X SEL
90 day: 19.05 mpg (US)
2007 Civic Lower Grille Block
So after a seeing Vman455's grille blocks and general ecomodding awesomeness I felt inspired to progress my grille block. I had the upper grille and hood-to-grille space blocked off with duct-tape covered styrofoam and that has held up fine for a couple years now. So I used some of that foam similar to the pool noodle stuff but this came in a sheet form initially intended for an in-window air conditioner. It's about 1/2" thick. I cut out the shape and wrapped it in some duct tape and then black electrical tape. It's just wedged into the grille - no fasteners. See pictures below for the results.
Before Block
After Block
There's a 6" x 2" gap left below the license plate. Any comments on if that should be enough airflow to prevent overheating? Temps right now are in the low 30s to high 40s - but with high humidity. Seems the car never warmed up all the way until about 5 miles into a drive.
Old 02-10-2013, 09:30 AM   #2 (permalink)
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
That looks good, I like it. Based purely on the amount of grill you have open, I think you have airflow still, as long as there is part of the radiator near the open section of the grill.
Old 02-10-2013, 03:47 PM   #3 (permalink)
Alexa - '07 Honda Civic LX
90 day: 38.32 mpg (US)
FX - '06 Infiniti FX35
90 day: 17.98 mpg (US)
Priya - '03 Saturn Ion 3
90 day: 27.81 mpg (US)
I've blocked my lower grille completely with tape and had no problem. Gained about 1MPG on the hwy as well!
