I miss this place
...and will try to be more civil.
My name is Tom.
I own several vehicles. I still own the 2000 Fiat Dakota Quad Cab, and it still has its 3d generation aerocap.
I still own the Karen-mobile, a 2005 Dodge Magnum SXT. Along the way, it decided to shred its 4-speed automatic transmission back in March (I tried to engine-brake by shifting into low gear on a 224,500 mile-old transmission - apparently, not a good idea). I have since swapped in a 6-speed NSG370 manual transmission, and a 2.87 rear end.
I now own a 2005 Dodge Grand Caravan SE+ with a 3.3L V6 and a 4-speed automatic, which I will be replacing soon. The body is rusting apart, which is common for this year/make/model.
I also own a 2001 Dodge Durango SLT with a 4.7L engine and 4WD. I am currently in the process of replacing its 4.7L V8 engine with at least one spun rod bearing, with a 2009 4.7L V8 engine that features dual spark plugs per cylinder, and a 9.8:1 compression ratio.
