Old 09-19-2014, 08:58 AM   #1 (permalink)
JDM hypeR mileR
OG VX's Avatar
The OG VX - '92 Honda Civic VX
90 day: 68.64 mpg (US)
Wiring MPGuino and Vac gauge to a Civic VX...
Hey guys,
I'm going to try and install a MPGuino and Autometer Vac guage on my VX this weekend. Can anyone please counsel me here on the easiest way to wire in all of the connections for each (including wire colors and/or ECU pin #'s) for a 92 Civic VX?
I've searched and see lots of ways to do these connections. Some seem cleaner/easier than others, but I'm hoping for some clarity here on which way is best (not just fastest).
For the vac gauge, I have a good thread to reference on where to pull the vacuum, but I still need help on wiring up the illumination. I want the gauge light to come on when the dash lights turn on.
Thanks in advance for vehicle-specific (92-95 Civic VX) advice!
Old 09-20-2014, 12:38 PM   #2 (permalink)
5 pin sensor
Zippy - '96 Honda Civic Hx
90 day: 40.77 mpg (US)
Boring - '11 Ford Fusion Sel
90 day: 21.88 mpg (US)
Probably the easiest way to wire illumination is to purchase an add a fuse line from Autozone. You can use a factory fuse spot like your headlights for example, and use the add a fuse kit to feed off of that plug for the power source for illumination.
I apologize but I'm not knowleadgable on the mpguino, I have wired in a vafc which taps wire off of the ecu harness which is under the passengers side lower kick panel in front of the door.
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
Old 09-20-2014, 06:08 PM   #3 (permalink)
5 pin sensor
Here ya go
http://ecomodder.com/forum/showthrea...-vx-22636.html
OG lean burn member
My civic thread
