I secured a table saw, but it immediately smells like it is burning
It is a Makita 2703 15 Amp 10-Inch Benchtop Table Saw. Its replacement sells for $528 on Amazon. Is it worth diagnosing the problem and trying to fix it? Having a tablesaw would be extremely useful. I have a circular saw, but a tablesaw would save a great deal of time. I have seen people screwing circular saws to the bottom of tables to rig tablesaws, but an actual tablesaw would be much better. Harbor Freight's version is $140 and eventually I will be able to get it a bit cheaper.
I could always put up a notification for Craigslist, but it would be far easier to find a used one back in the Phoenix area, I just rarely drive down there. What do you guys think? |
Make sure you're using a extension cord that's at least a 12/3 cord. 12/3 carries 15 amp. Anything less will shorten the saws life. (burn up) Ryobi makes a decent Table Saw that is inexpensive. ;) No need to spend big bucks. > |
Wood bring or motor burning?
It immediately smells like it is burning. I did not try to bring wood or bring a motor.
As soon as I turned it on. The blade spins freely.
Assuming it has 'em, check the brushes.
This page does not show brushes on the parts diagram, but owners mention it: https://www.ereplacementparts.com/ma...8_216_217.html
I will check it when I finish replacing my timing belt. |
If the rated RPM is higher than 3,600rpm it's going to have brushes.
