I want to kill my alternator!
I want to kill my alternator, but not permanently. There was another thread on here where someone experimented with an alternator kill switch, and accidentally killed their alternator. I think they grounded a signal wire and it ended up frying something. I'd like my alternator kill switch to also be capable of reviving the charge capabilities.
My car is an Acura TSX (Euro Honda Accord). Any thoughts on how to wire in an alternator kill switch without actually destroying the charging system? Do you have experience with alternator kill switches in a Honda? Here is the charging system diagram of the TSX. Apparently it does have an ELD. If the image is too small to read, let me know and I'll see if there is a way to upload something larger. http://i7.photobucket.com/albums/y26...rum/TSXalt.jpg |
Grounding the alternator's C terminal will put the alternator in the 12.5v low output mode. I keep mine there most of the time. I have disconnected the wire to the ECU and ground the C terminal manually through a resistor. The resistor might not be necessary, but I put it there anyway. I might've used a 100 ohm, I'm not sure. The alternator won't be totally off if you do this, but it won't be working as hard either. You'll want a voltmeter in the car. Running too high of an electrical load in this mode will drain the battery.
I've never noticed a fluctuation in voltage; it's always remained at 14.4v from what I recall. I wonder if running a 20% underdrive on the alt has affected the output behavior?
It seems the car already does it's best to reduce fuel consumption if it has the ELD, and even goes into high output mode when decelerating (according the the forum linked above). Although I read a lot on how to bypass the ELD to run in high output mode, I'm still not any closer to figuring out how to disable the alternator. I figured I could put some massive switch in between the main output wire of the alternator. Any reason why I couldn't just disconnect the output? I'm quickly loosing steam on this project since there doesn't seem to be a clear way to disable the alternator, and it's already efficient in the first place because of the ELD. |
I have a photo of an alternator (or more precisely generator) delete on one of smoky Yunicks race cars, he dumped the standard engine mounted generator and instead mounted a small generator in front of the radiator complete with a propeller attached. There wasn't an in-car computer to run back then (the 1970s I presume), but there was the ignition system to power. Unfortunately the race scrutineers called this mod "cheating" and wouldn't allow him to run it. Obviously you won't be doing race speeds on public roads, so how effective this would be I have no idea. An existing electric thermo fan might generate some current if wired in correctly to charge the battery rather than drain it.
Not sure the dimensions of a compressor clutch but if you could control it with a switch and monitor battery voltage you would see a noticeable gain in mileage during daytime highway driving. You would be going to zero resistance from the alternator Just a brain storming idea, I would be interested in something simple like that. Because the alternator is mainly a mechanical device there really isn't a feasable way to prevent it from turning mechanical energy into electrical enegergy |
The alternator can be prevented from turning mechanical energy into electrical by removing the output wire. There has got to be a better/simpler/cleaner approach to switching the alternator on and off though. I'm attempting to read up on modern alternators. Honda has 4 smaller wires in addition to the large output wire that I haven't figured out what they do. Some probably energize the windings, and I believe 1 of the wires monitors voltage on the battery. |
The regulator sends a current to the alternator which creates a magnetic field. You would just need to have a switch between the regulator and the alternator to disrupt the magnetic field.
However it looks like all alternators have internal regulators so you would need to find where regulator output wire is. |
I found a very helpful document that describes what each of the 5 wires on the alternator does. From my understanding of the below explanation, it seems there are 2 ways to disable the alternator.
1. Supply 5v on the FR circuit tricking the ECM into thinking electrical demand is zero. 2. Ground the C circuit output. Quote:
From your description, I'd start by grounding the C wire. Its the easiest thing to do. Its meant to turn the alternator on/off so a logical place to start. You could put a resistor in there to make sure you don't toast anything. You might want to measure current while you're at it to see if you need it or not.
