Old 02-25-2019, 08:39 AM   #1 (permalink)
I want to make an uneconomical car get good gas mileage (2011 Mustang GT)
So I currently have a 2011 mustang GT and I am looking for lightweight, aerodynamic wheels and high efficiency tires. Stock takeoffs would be amazing. My current lug pattern is 5x4.5 or 5x114 mm. I have gotten 27 miles per gallon out of this car on road trips, but I would like to make that my daily driving average. I am planning on putting a 3.15 rear end gear in the car and possibly lowering it. in a perfect world I would be able to take off my eco wheels and tires slap on some drag radials and go have some fun with e85.
Old 02-25-2019, 09:18 AM   #2 (permalink)
The 3.15 rear is probably just about the best thing you can do.
Old 02-25-2019, 10:36 AM   #3 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Unless they make a lower ratio...
An economical tune might be an option.
Old 02-25-2019, 11:01 AM   #4 (permalink)
If you are able to remap the fuel tables you could run lean burn while cruising down the highway.
If you can go from close to 14.7:1 to more like 16:1 that should give you at least 10% more mpg
Old 02-25-2019, 11:31 AM   #5 (permalink)
I do have HP tuners. Hmmm
Old 02-25-2019, 12:29 PM   #6 (permalink)
Just make sure you run a normal fuel table when manifold vacuum more than 7 or 8 inches of Hg.
You need a normal air fuel ratio as you get anywhere close to wide open throttle.
When I did my lean burn the secondary jets opened up starter dumping fuel into the intake around 8 inches of Hg and I never burned a valve.
Old 02-25-2019, 12:30 PM   #7 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I would use caution when adjusting the a/f ratios. I dont know ford very well but I assume there are cam phasers being used and you should be able to control then with an hp tuner. Anything you can do that will reduce pumping losses (by increasing the throttle opening) at cruising speed will help. E.I. taller gearing, higher a/f ratio, changing cam timing, etc.
How much highway driving do you do?
Old 02-25-2019, 04:49 PM   #8 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 79.47 mpg (US)
Send a message via MSN to jakobnev
...and high efficiency tires
You can make your current tires more economical just by increasing the tire pressure.
Old 02-25-2019, 11:42 PM   #9 (permalink)
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
Wrap your headers and if you're lowering your vehicle, consider just lowering your front end to establish positive rake.
