Old 05-05-2014, 01:19 PM   #1 (permalink)
PSmodder lurker
ICE technology evolution, extreme reduction of weight & parts
A reciprocating...rotary...axial engine?!! For a comparable engine size/power; extreme 30% reduction of moving weight and reduction of spark plugs and injectors! Unexpected; unusual wear on that all-important reciprocator/ball joint and compression head ring.
Call it the 'Gatling'. Next, how to super/turbocharge that...
Old 05-05-2014, 03:59 PM   #2 (permalink)
Duke
Doesn't the US Navy have torpedoes which use a similar engine;which runs on a gasoline mixture which provides its own oxygen?
Old 05-05-2014, 07:54 PM   #3 (permalink)
...beats walking...
All the *old* sliding seals problems of a Wankel...with...the *new* problems of socketed push-rod (reciprocator) pistons!
Plus, that's a LOT of mass rotating around there...have they ever heard of the gyroscopic problems encountered with the Gnome aircraft engines of WWI?
Old 05-05-2014, 08:18 PM   #4 (permalink)
PSmodder lurker
Originally Posted by Old Tele man View Post
All the *old* sliding seals problems of a Wankel...with...the *new* problems of socketed push-rod pistons!
Plus, that's a LOT of mass rotating around there...have they ever heard of the gyroscopic problems encountered with the Gnome aircraft enginges of WWI?
A very convoluted and busy system but at least this axial design seems more balanced; have easier seals, opposed pistons and cylinders & connecting rods are NOT spinning. And it is multi-fuel!
The Following User Says Thank You to botsapper For This Useful Post:
aerohead (05-06-2014)
Old 05-07-2014, 04:30 PM   #5 (permalink)
Axial engine - Wikipedia, the free encyclopedia
Wikipedia lists it among the 4 modern of 14 total variants. aerohead is right.
The most well-known application is in torpedoes, where the cylindrical shape is desirable. The modern Mark 48 torpedo is powered by a 500 hp swashplate engine geared to a pump-jet propulsor. It is fueled by Otto fuel II, a monopropellant that requires no oxygen supply and can propel the torpedo at up to 65 knots (120 km/h) (74.56 mph).
