Old 01-10-2014, 02:34 PM   #111 (permalink)
This will be the 93rd time I've explained it, but both "A" and "B" suffer PUMPING LOSSES, losses which are too great to overcome with ANY improvement in the things you seek. Read up on our own EM cylinder deactivation threads. There is a REASON NONE of the OEM cylinder deactivation schemes simply kill injectors or hold valves open and the reason is this: It does not work. It does not work. It does not work. It does not work. It does not work. It does not work.
CFECO (01-10-2014)
Old 01-10-2014, 02:40 PM   #112 (permalink)
CFECO
CFECO's Avatar
X-Car - '11 Homemade 2+2
Velbly1 - '17 Toyota Camery XSE
90 day: 29 mpg (US)
Velbly2 - '13 Toyota Tundra
90 day: 18.03 mpg (US)
"kill injectors or hold valves open"....Must do both.
I'll go back and read the past threads on it.
Old 01-10-2014, 02:45 PM   #113 (permalink)
Thank you.
Old 01-10-2014, 02:57 PM   #114 (permalink)
CFECO
CFECO's Avatar
90 day: 29 mpg (US)
I found this... some guy wrote,
"Thanks for the figures metro; some rough extrapolating says maybe +15% could be expected on average... that's about what DoD for larger engines gets too... so for the Tempo I'd be looking at +5 or 6 mpg. Nice, but perhaps I won't be pulling those two pistons after all. :/"
I'll take 15% for a start...I go read more now
Old 01-10-2014, 03:12 PM   #115 (permalink)
Figure 7-30% potential fe gains with current Dod schemes.
Old 01-10-2014, 03:24 PM   #116 (permalink)
CFECO
CFECO's Avatar
90 day: 29 mpg (US)
Old 01-11-2014, 10:28 AM   #117 (permalink)
The PRC.
A 0 cylinder conversion (i.e. turn it off) would be better.
Old 01-11-2014, 10:40 AM   #118 (permalink)
CFECO
CFECO's Avatar
90 day: 29 mpg (US)
It is off...
Old 01-11-2014, 10:40 AM   #119 (permalink)
The PRC.
Is it moving ?
Old 01-11-2014, 10:56 AM   #120 (permalink)
CFECO
CFECO's Avatar
90 day: 29 mpg (US)
Through space...quickly too!
Conversion idea, 2L inline 4 -> piston boosted 1.0L 2 banger? Warning....Long thread JoJotheTireMan EcoModding Central 56 06-12-2011 03:09 AM
Tips needed for eco-driving my diesel truck! nubbzcummins Hypermiling / EcoDriver's Ed 65 12-07-2010 01:37 PM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 10:35 AM
1992 Metro sedan needs a new engine - What/Where/How - advice appreciated greatly! Crono EcoModding Central 26 11-18-2008 01:42 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
