Old 01-07-2015, 09:19 AM   #81 (permalink)
Originally Posted by cowmeat View Post
Man, that looks awesome!
FYI - I revised my original schematic to I only need one on/off pop-up (the one in the middle). That will be the clutch switch, which will need to be on or off for long periods of time. The thumb button (90 degrees) and the top one need to be momentary buttons, they will control the regenerating and the injector kill.
Sorry, thought I had PMed you that info, and thanks for the work you've put into it!
No problem and you're welcome. Its been fun working on these things and switching it is no big deal.
What switches do you need (NC/NO) for the thumb and forward buttons?
The Following User Says Thank You to Daox For This Useful Post:
cowmeat (01-07-2015)
Old 01-07-2015, 11:38 AM   #82 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
I need the top one (brake regen) to be normally off, so when I press it I get full regeneration with brake lights.
The kill switch I guess Balto or Ecky will have to chime in on. I have exactly the same set-up as Balto, except I have a pop-up on/off button i.l.o. a momentary button, so I'm not sure what kind of momentary it would need since there's a relay involved and I know practically zero about anything electrical.
Old 01-08-2015, 04:29 AM   #83 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Daox that's just amazing idea to 3D print parts for EM cars...
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 01-08-2015, 09:26 AM   #84 (permalink)
Thanks. I'm always looking for more ideas on what could be made. If you guys have any, toss em out there.
Old 01-08-2015, 10:00 AM   #85 (permalink)
Focus - '05 Ford Focus tdci Futura
Trotlle body spacer plates? But you'll need exact massurements
Old 01-11-2015, 07:03 PM   #86 (permalink)
Daox, Theres a MILLION things you can make with that.
1. Intake spacers
2. Differential mount bushings
3. Transmission mount bushings
4. power steering rack bushings
5. Engine mounts
6. wheel spacers
7. Subframe bushings
8. throttle body adapters
tons of other bushings I just don't know what the 3d printer can and can't do. But most of those are solid block with holes type applications. I couldnt see them being an issue
You could make those for 240sx evo sti wrx audi 2.0t bmw 335i g35/350z
Wheel spacers would be SUPER easy to start with. Plus have the biggest market since they would be pattern specific not car specific
Do one run of 50-100 parts each and be done with it. Have people send you accurate measurements of parts needed and send them a free part in return.
You could google all the info to make spacers today.
Old 01-11-2015, 08:38 PM   #87 (permalink)
Its really endless. I saw a guy at a truck show that had a plasma cutter on a xy table and sold cut outs of trucks, homes, anything you wanted. Some people would paint, some would attach to a fence or use as a sign. A fire fighter purchased a fire truck cut out.
Another guy had a vinyl cutter and was making signs. Basically it just cut out stickers like and he would stick one on top another to make the sign.
Old 01-11-2015, 11:05 PM   #88 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
It needs to be a normally open switch, or N/O. I would LOVE to have this for my car as well.
The Following User Says Thank You to Baltothewolf For This Useful Post:
Daox (01-12-2015)
Old 01-15-2015, 11:38 AM   #89 (permalink)
Stickboy
Send a message via Yahoo to jodydewey
Great Job
Great Job on the 3D printing of your spacer. I myself have started printing things using my CTC Dual Extruder 3D printer. Mine can print in both PLA and ABS but I have problems with larger parts printing without warping with ABS so I mainly use PLA. I have been printing things like knobs, brackets, and such for my truck so far. I am leary of printing engine parts because the heat involved may melt the plastic. PLA and ABS have a melting point of 230c (446 f) so maybe items that are not in that temperature range may work well. Anything close to the exhaust may be an issue though.
Old 01-15-2015, 11:44 AM   #90 (permalink)
Stickboy
mooneye discs
Another idea: could probably whip up a reusable widget for attaching wheel discs to steelies that is more practical than the zip-tied coroplast bundles I made:
If you could come up with a universal or near-universal widget, I bet people would go for them.
Instead of making those you can get regular mooneye hubcaps for any vehicle...
They offer them in any size needed. Kinda pricey but they are very good quality. I bought a set for my 95 geo and then moved them to two different cars over the years.
