03-02-2010, 01:48 AM
#32 (permalink)
Pokémoderator
Hello -
Here you go :
Gen II (I think another, better image is in the mail) :
Gen I Dimensions :
Gen I Performance :
* - Mileage may vary based on weather, traffic, AC use, and driving style
CarloSW2
The Following User Says Thank You to cfg83 For This Useful Post:
03-03-2010, 08:55 PM
#33 (permalink)
ecomonkey
angle of rear roof slope
that rear window area "looks" like it is too steep and air would detach? do any of you know the angle? i know its an awsome cd car thats why im asking.
03-08-2010, 02:59 AM
#34 (permalink)
Pokémoderator
Hello -
Here are the pictures I wanted to post, but the item hadn't arrived yet :
I guess that the "rear wheel" shadow means that this picture probably has some perspective in it, .
The vertical lines in the pictures are the fold-out crease.
CarloSW2
03-08-2010, 08:43 AM
#35 (permalink)
Too bad the top is a different scale than the front and back. Notice that the mirror supports are kind of "buried" in the rear view, so yes, there is a little perspective distortion.
03-08-2010, 02:01 PM
#36 (permalink)
Pokémoderator
Neil -
I totally missed that. Thanks. Back in post #20 you can see the same thing. I'll bet they came from the same source.
CarloSW2
03-09-2010, 06:47 PM
#37 (permalink)
angles
At 4-locations,moving back along the template,for 10,20,30,and 40% aft-body,I measured 9,20,19,and 15-degrees,respectively.
With the racing boat tail,the terminus angle is 11-degrees.
If you lay a straight-edge across the back of the boat tail and up over the backlight,it measures 16-degrees.
03-09-2010, 09:49 PM
#38 (permalink)
Also, in the low angle pictures I've seen, you can see the rear wheels from the front because the rear track was quite a bit narrower than the front.
03-17-2010, 12:50 PM
#39 (permalink)
Is it just me, or is the "Impact" (prototype of the EV-1) a much better looking car?
The nose is obviously different, and I detect a deeper contour in the doors and a slightly "hunched" rear fender -- anything else different that you can see? Was the Cd different?
03-17-2010, 02:07 PM
#40 (permalink)
Maybe it is tapered from the sides? That is, instead of looking at airflow from the side of the car, look at it from the top.
