Old 05-30-2014, 06:37 PM   #1 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Improving Alternator Efficiency
http://www.delcoremy.com/documents/h...ite-paper.aspx
Old 05-30-2014, 07:24 PM   #2 (permalink)
Heilopower
Platinum Ghost - '14 Ford Fusion SE
90 day: 33.44 mpg (US)
I read this document a few weeks ago and was impressed with the improvements that are possible with alternators. Problem is that such technology has not reached the US automotive market. Is there any aftermarket source for such an alternator besides one for a bus or a diesel truck? Seems like the average driver is always left to be a bottom feeder as improved technology filters oh so slowly down to our level.
Old 05-30-2014, 07:47 PM   #3 (permalink)
...beats walking...
Also, notice that the paper was published in 2008 -- six years ago -- prior to GM's brankruptcy and Delco-Remy's demise.
The Following User Says Thank You to gone-ot For This Useful Post:
Cobb (08-28-2014)
Old 08-28-2014, 07:31 AM   #4 (permalink)
Thank you eco modder for another misleading thread.
Was the topic about someone who wants to modify their alternator, no. Was it about a new alternator that is more efficient, no. Its an article from 6 years ago from a company that went bankrupt about design flaws in existing alternators.
Anyhoo, Ive often wondered about using one of these PM modded alternators for wind turbines.
Low Wind Permanent Magnet Alternator Wind Turbine Generator PMA | eBay
PMA Permanent Magnet Alternator for Hydro or Gas Engine Made in The USA | eBay
Old 08-28-2014, 09:08 AM   #5 (permalink)
That paper helped me to decide to finally re-do the alternator and water pump "gearing" and rework the entire accessory drive system on my Tempo.
http://ecomodder.com/forum/showthrea...ork-20558.html
Carbon (09-04-2014)
Old 09-03-2014, 02:15 PM   #6 (permalink)
I wouldn't say its miss leading.
We could adapt this new technology or reverse engineer it and put it on a 20 year old vehicle.
That paper actually puts numbers to a lot of alternator related things.
It also makes one heck of a case for doing an alt delete even if their savings numbers are only half correct.
They say "Increasing alternator efficiency can, and will, measurably reduce fuel costs". That is pretty big statement.
I was going to do a test to calculate efficiency of a belt, using electric motor, kill-a-watt meter and idler pulley. But I read it in there, the belt has an efficiency of around 98%. I was expecting to see at least a mid 90% number.
Daox (09-03-2014)
Old 09-03-2014, 03:46 PM   #7 (permalink)
Optima Hybrid - '13 Kia Optima LX Hybrid
90 day: 33.02 mpg (US)
Outlander - '15 Mitsubishi Outlander SE AWD
90 day: 25.17 mpg (US)
Peak efficiencies at full output vary from 55% to almost 80%.
I would argue that, at least with GM's current alternator design, that the losses are not as great as shown in this paper.
Most alternators made in the last 10 years are not simply on all the time. Instead, the field coils are PWM controlled to react to load demands and compensate for variable RPM operation. See Pin C(Terminal L) below:
Old 09-03-2014, 10:35 PM   #8 (permalink)
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 18.73 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
I think the cars I drive could use some alternator improvements.
Old 09-04-2014, 08:54 AM   #9 (permalink)
LOL... Indeed. The only real options are to go with a lower output unit or to just delete it. You also could redo the pulley ratios like Frank.
These options technically don't increase the efficiency of the alternator though, but rather reduce the load as seen by the engine. You could swap in an OBD2 PCM system that monitors the electrical system and can control the newer unit, but that is outside the scope for most people.
My comment was more to the above where someone said that no such efficiency efforts had been made in the US market, which is wholly false. As is the statement that Delco-Remy is dead.
The Following User Says Thank You to Carbon For This Useful Post:
101Volts (09-09-2014)
