12-15-2021, 08:43 AM
Oyuki - '90 Toyota Corolla TX
90 corolla diesel engine flush yay or nay
Good morning,
i bought a 1990 toyota corolla 1.8 diesel idi. It has 290,000 km. Perhaps an engine flush would loosen the crud and sludge in the engine and make better fuel mileage. I have been getting around 70 km/g around 44 mpg. I have heard about engine flush with automatic transmission fluid, kerosene, or diedel. I am a little apprehensive to flush such an old engine, because i have heard that the after engine flushes some old engines begin to leak and i would not like this.
Cheers
Jorge
1990 toyota corolla TX 1.8 Diesel sedan
40 MPG @ 50 km/h /31 mph highway
12-15-2021, 11:37 PM
If it starts leaking after a flush, the seals and gaskets are the problem. When it comes to which fluid to use for flushing, I have seen it done mostly with kerosene, and it can be done at different stages.
12-17-2021, 12:34 AM
Too many cars
Where will the crud go once it's loosened? That would be my concern.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
12-17-2021, 09:42 AM
Hopefully into the oil filter but may end up in the pan, either is ideal. It's when it goes floating about that it causes damage
12-17-2021, 10:04 AM
I would only "flush" if you have an immediate and serious issue that may be resolved. Otherwise just add a small amount of ATF, MMO, Seafoam, etc.
Flushing the engine would be akin to surgery or chemotherapy. Make sure the treatment matches the ailment.
The Following 2 Users Say Thank You to ksa8907 For This Useful Post:
12-17-2021, 10:12 AM
Been wanting to add: flushing was fatal to the #1 crank rod bearing in a s10 I bought for my son. It died 50 miles later.
May not have been the actual cause but definitely a contributing factor
12-17-2021, 10:19 AM
The closest thing I've done to a flush was a couple very low mileage oil changes and it seemed to work. I would try that instead. Not even close to as risky either.
Try like 1500-3000 mile changes with syn.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
12-17-2021, 09:41 PM
Originally Posted by somerandomguy
Good morning,
Cheers
Jorge
If you flush, do not replace the entire oil with something other than motor oil.
Option 1:
Frequent oil changes with cheap oil, about once every tank of gas untill the engine is sufficiently clean.
Option 2:
Get the oil up to temperature, shut the engine down, add 0,5L diesel to the crankcase, let the engine idle for 15 min, shut it down and drain the hot oil quickly.
Under no circumstance replace the entire engine oil with diesel/ATF/whatever that isn't motor oil.
That will likely cause bearing damage.
12-18-2021, 09:21 PM
#9 (permalink)
Even the flush with kerosene that I remember was done by adding a small amount of kerosene to the oil, allowing it to circulate between oil changes which were done at a shorter interval while the engine was undergoing a flush.
12-19-2021, 01:29 PM
#10 (permalink)
You're not supposed to drive the car with the diesel/kerosene added to the oil.
Only let it idle for a few minutes and then drain it.
Otherwise the oil might be too thinn and your bearings might suffer.
