Go Back   EcoModder Forum > Forum News & Feedback
LinkBack Thread Tools
Old 03-11-2011, 03:32 PM   #91 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
Originally Posted by PaleMelanesian View Post
All I'll say is I have mine into the "margin of safety" range.
I backed down a little when the back end started skittering sideways on speed bumps.
Would you consider 50 psi to be within that range for these tires?
Old 03-12-2011, 10:59 PM   #92 (permalink)
ktaylor's Avatar
Burgandy B*tch - '99 Buick Regal LS
90 day: 27.78 mpg (US)
Faze - '86 Yamaha FZ 750
90 day: 36.83 mpg (US)
My guess is that too low or too high pressure would each have different stresses, and neither would be good for the tire's integrity?
This is true. I learned about fatigue in 2nd year materials at UBC and while both instances of too high and low pressure have negative effects during operation, I believe higher pressure is much worse. Ductile materials (rubber) fail in tension, not compression. As you increase the internal pressure, you increase the tensile stress in the tire. The average pressure is what you would plot on an S-N diagram (refer to the wiki page reffered to) where S is average stress and N is cycles to failure. If you increase stress (pressure) by 2x, you greatly reduce the number of cycles to failure (much more than half) due to the nature of the curve in the low stress region.
Some tires when "properly" inflated have a bulge at the bottom. This adds another type of stress which propagates through the tire as it rotates. When inflating tires closer to sidewall max the bulge disappears. The reduction of those additional stresses may negate the additional stress added internally, although that bulge is material in compression and as stated, ductile materials fail in tension. Either way its not like you're living on the edge if you put your tires to sidewall max. Tires are tough and take a hell of a beating in their life.
On that note, everyone should check when their tires were made. Theres a 3 or 4 digit code written on the sidewall in an oval stating the week and year they were made. I belive the first 2 numbers are between 1 and 52, for each week of the year followed by 7 for 1997 or 05 for 2005, etc. for the year they were made. You should google it because after 8 years I believe, tires are pretty much garbage (Yes they have an expiry date, google it).
Old 03-12-2011, 11:13 PM   #93 (permalink)
Haw haw haw- throwing tires out cuzza the date of mfg! Run 'em til they pop.
Old 03-12-2011, 11:37 PM   #94 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
I keep a close eye on my bicycle tires. When the age, they get little cracks & splits in the side walls.
That's when I decided it's time to replace them.
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 03-13-2011, 03:21 AM   #95 (permalink)
My understanding of it- especially as it relates to gumwall bicycle tires- is that the main purpose of the "rubber" is to protect the cords. I've had gumwalls so weatherchecked the gum came off in chunks but the tire still held air.
P.S.
Once the fabric has been woven between the beads, and the tire has its basic shape, it is coated with rubber. The rubber is mainly there to protect the fabric from damage, and has no structural importance.
http://sheldonbrown.com/tires.html
Old 03-13-2011, 09:00 AM   #96 (permalink)
P.S.
Bicycle Tires and Tubes
That's sounds true to my ears. But, if the walls are cracked, that means the
weather can get to the cords. So, it's only a matter of time.
I'm running tubes, loaded with that green goop. Keeps them from leaking down so fast.
Cheers,
Rich
Old 03-14-2011, 11:04 AM   #97 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Agreed. Exposed cords = time for the trashcan.
Old 03-14-2011, 11:30 AM   #98 (permalink)
The PRC.
You wait for the cords to appear ? Jeebus.
I just check these regularly. The law here is a minimum tread depth which these are set at...
Old 03-14-2011, 05:28 PM   #99 (permalink)
Aw, you're tossing them right when they're about to get the best fe!
Old 03-14-2011, 06:19 PM   #100 (permalink)
The PRC.
Last time I checked LRR tyres, non were slicks.
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
Tire / Wheel Mods? NeilBlanchard EcoModding Central 10 09-30-2009 04:24 PM
Tire pressure and fuel economy RESULTS 07b2300 EcoModding Central 56 10-31-2008 12:40 PM
NASA sponsored competition rewards efficiency mods in private aircraft MetroMPG General Efficiency Discussion 0 08-13-2008 10:35 AM
Getting more efficiency out of a ZX2. Small list of mods and driving tips for it. koihoshi EcoModding Central 9 07-20-2008 04:26 AM
