Old 03-29-2013, 11:36 AM   #1 (permalink)
Exhaust turbine with electric generator
Hello people
I come from switzerland. Sorry my english is not so good.
I have a Idea, but this Idea is not new.
At the end of the muffler, we fix a exhaust turbine with a electric generator.
The generator charge a battery.
So we thus use the exhaust energy.
10-20% better efficiency?
Instead of a exhaust turbine, one could uses a little roots-charger as exhaust turbine?
cu
PowerPiston
Old 03-29-2013, 11:57 AM   #2 (permalink)
In order to get power out of the exhaust there must be a pressure/temperature drop between the two sides of the generator (be it a turbine or roots type charger). I would stick to a turbo type setup since it is designed to do what you want. A roots type charger really is not designed to take power out of something, its only designed as a compressor. I am assuming you mean a roots charger like this: Roots-type supercharger - Wikipedia, the free encyclopedia
Old 03-29-2013, 12:26 PM   #3 (permalink)
I know the roots-charger. A roots-charger is only a pump, and a pump can also drive a generator. A exhaust turbine is relatively expensive and not very insensitive. So my idea a roots-charger instead a exhaust turbine.
Old 03-29-2013, 12:36 PM   #4 (permalink)
Sorry can't post links. Next post sorry
Old 03-29-2013, 12:37 PM   #5 (permalink)
This engine uses also the exhaust energy.
The 5-stroke petrol engine so good as a diesel engine.
This engine uses the exhaust energy with a bigger piston.
The piston is greater than a larger force acting on the piston.
My idea is without piston, but with exhaust turbine or a exhaust-pump.
In the exhaust gases is still a lot of energy.
5-Takt-Motor - Konzept
Ilmore
Ilmor Engineering - 5-Stroke Concept Engine.
Fünftaktmotor
5-Takt-Motor
Old 03-30-2013, 02:40 PM   #6 (permalink)
The generator charge a battery. So we thus use the exhaust energy.
Discussed >here<:
Originally Posted by Air-Hybrid View Post
"TIGERS (Turbogenerator Integrated Gas Energy Recovery System) is a water cooled switched reluctance generator coupled to an exhaust driven turbine. It is capable of operating in exhaust temperatures > 900ºC, at speeds up to 80,000rpm, delivering a shaft power of 6kW"
Controlled Power Technologies... TIGERS
