Old 08-06-2012, 06:23 AM   #1 (permalink)
toc
Sonata97 - '97 Hyundai Sonata GL
90 day: 25.96 mpg (US)
Pulsar - '03 Nissan Pulsar ST
90 day: 36.09 mpg (US)
Lancer - '04 Mitsubishi Lancer
90 day: 31.11 mpg (US)
Lancer 2.0 - '09 Mitsubishi Lancer
90 day: 27.1 mpg (US)
Intake Valve Timing Control
I was reading the service manual for a car with VVT.
I can see in the manual this:
The valve timing control system is utilized to control intake valve
opening and closing timing. Engine coolant temperature signals,
engine speed and throttle position are used to determine intake
valve timing.
The intake camshaft sprocket position is regulated by oil pressure
controlled by the intake valve timing control.
When ECM sends ON signal to intake valve timing control solenoid
valve, oil pressure is transmitted to camshaft sprocket. Then, intake
side camshaft is advanced.
OK - so by forcing more oil to the camshaft the pressure advances timing.
Directly below is a table.
When coolant temperature is low (warm up type), and engine speed is 1150 - 4450 RPM, and the base fuel schedule is above 3 msec, and the neutral switch is off, the solenoid is ON.
The same is also true when the engine has warmed up, the RPMs are 1150-4450 and the base fuel schedule is above 7 msec, and the neutral switch is off.
Thus timing is advanced, and valve overlap increases.
So by shifting into neutral, I'm potentially missing the ability to get more advanced timing out of the car.
I wonder if there's any merit in manually controlling that valve? If it's on, then timing could be advanced more often..
What are the thoughts here?
I can probably take direct control of it, I doubt it's pulsed on / off, and instead held on during those conditions.
I think I can remove the RPM requirement and base fuel schedule requirement and simply have it on when engine is warmed up (advanced timing when warmed up...)
Old 08-06-2012, 12:11 PM   #2 (permalink)
What do you think you have to gain by advancing the cam timing at idle?
Old 10-20-2012, 11:33 AM   #3 (permalink)
EZP 545's Avatar
Inlet variable valve timing
From some "dyno type"measurements, monitoring petrol fuel energy usage in, and Kw generated out, A prius engine carburated is returning 17% at the 10kw level. (shaft estimated at 21%). This is run at 2000rpm, because of some other constraints, so maybe about the ball park. If anyone knows if this is so, please comment.
A switch to LPG, with a crude mixer,and regulated from BBQ bottle, enabled a 5KW run, but consumed around 3kg per hour. This came out at energy in to energy out of about 10% total, and maybe 12.5% shaft. My thoughts are further tuning, may improve this, but how about this idea.
The Prius engine shortens its inlet stroke lenght by leaving the inlet valve open for about 25% of the upward stroke. If the inlet valve cam gear was advanced on the timing chain, a higher compression ratio for the LPG could be obtained, maybe up to 13:1. Risk would be of the valve clipping the piston at the begining of the intake stroke, when in the vvt off position. Nice if this worked without a cam grind.
Any Ideas?
Old 10-20-2012, 12:59 PM   #4 (permalink)
The PRC.
+1 The idea behind the VVT system is to provide low to mid-range torque for an engine which is tuned to give more top end power. Without it engines like the Honda Type-R (200hp for 1.6 litres) or even my own car's 1.0 3cyl (68hp) would be undriveable in the real world.
I can't see a benefit at idle. You could of course turn the engine off instead.
Old 10-20-2012, 05:01 PM   #5 (permalink)
Advancing the cam at low load is bad in every single way. There's a reason it's fully retarded at idle.
Old 10-20-2012, 06:00 PM   #6 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
You may want to see this:
It's VW r32 engine with turbo and variable valve timing all controlled by MegaSquirt 3 ecu. And you can change timing on the fly regardless revs, load, temp, etc.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
