Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 11-08-2010, 10:55 PM   #21 (permalink)
My 1967 Huffy has a Strumey Archer 3 spd hub and I successfully replaced some of the cracked gears with parts from another unit. The older books call for 30w non-detergent oil lubrication. White grease won't hurt them but the oil works better. Cable tension is critical too. I switched from stock 48/19T to 40/19T for stop and go city riding. The common S_A models were AW-1 and SW-1. I doubt you would need to take the spokes off unless they are damaged. Another bike I put together is a ladies' Huffy frame, 26" rear wheel with a Shimano 3spd coaster brake unit and a 20" plastic front wheel...very comfortable and responsive. Cogs from a derailleur cluster can be cut inside to fit an internal gear hub so that two gears can be mounted together. A derailleur can be fitted to shift between them for a six speed rear end. The rear gears should be 3 teeth apart and the front rings should be 4 teeth different. Example: 16/13T rear and 44/40T front.
The new 10 spd Shimano hub with disc brakes is something I'd like to try for an aero bike.
News: Utah Considers Joining 80 MPH Speed Limit Club MetroMPG General Efficiency Discussion 68 11-04-2009 07:25 PM
Slow Speed Issues and an Auto Tranny Bobsterz Hypermiling / EcoDriver's Ed 4 06-28-2008 10:10 PM
Field Weakening Experiment for Speed Increase TomEV Fossil Fuel Free 12 04-10-2008 03:53 PM
Series Motor - Speed vs Torque TomEV Fossil Fuel Free 3 03-02-2008 12:27 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
