Old 01-16-2011, 06:33 AM   #1 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Which way would you install skibox
Skibox Skibox - Zorg bij de ski voorbereiding voor een goede dakdrager
I was wondering why skibox factories instruck to install them this way and not the other way to get kammback effect?
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 01-16-2011, 11:46 AM   #2 (permalink)
in tents
dennyt's Avatar
The Adventure Wagon - '94 Subaru Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '11 Surly Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
Do an ABA test.
Old 01-16-2011, 03:14 PM   #3 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Inside the car. That's where the Wife and I carry our 2 meter long crosscountry skis.
I think that the proposed way of mounting would be better aerodynamically. Yes, the front could be a little more blunt, but the rear has a sharp cut-off, so installing it backwards would not be advised.
Old 01-17-2011, 01:55 AM   #4 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
I did some searching and found these videos:
about bars:
I want my own miniature wind tunnel, like that
and at the box:
Version at the 1.30 has already a kammback shape .
Old 01-17-2011, 02:39 AM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
One thing I noticed on the vids is that the Thule boxes were always mounted in the center of the roof, while most drivers mount them asymetrically on one side (because it's easier to reach). I wonder how much of an effect that has?
I'd like to see nice side pictures of windtunnel testing...
I did find this aerial view, from which you can clearly see the car is Kamm'ed much better than the box:
I bet that one would give Aerohead a headache
Old 01-17-2011, 08:23 AM   #6 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
As there's more drag on one side, there will be a slight yaw moment which will need to be corrected through the steering - and steering increases tyre resistance. I doubt it'll show up during driving and be much worse than a centermounted box though.
Probably the worst thing anyone could do, is putting 2 narrow boxes on the roof.
There's quite a few instances in aviation history where putting 2 external fuel tanks next to one another didn't increase, but decreased the range of the aircraft.
The Following User Says Thank You to euromodder For This Useful Post:
Piwoslaw (01-17-2011)
Old 01-17-2011, 10:19 AM   #7 (permalink)
aero guerrilla
Piwoslaw's Avatar
There's something I didn't know... Kinda make sense, though, thinking about how much the gas pedal gets pressed when being passed by someone else (someone BIG, for example). Maybe I should get a sticker:
DO NOT PASS!!
(IT KILLS MY FE)
Old 01-21-2011, 06:26 PM   #8 (permalink)
which way: stability
My opinion is, that with rounding of the trailing edges,and reversing the carrier,the drag would be reduced.
The issue might be how that would affect the center-of pressure for the car/carrier combination.The 'streamlined' form would push the COP forward,which is NEVER good for crosswind stability.
So maybe for safety,THULE compromises a bit on drag.Not bad thinking!
Old 01-21-2011, 06:31 PM   #9 (permalink)
in tents
dennyt's Avatar
Subaru
I think putting the box backward would raise the stagnation point and force more air under the box, which would increase the interference drag.
Last edited by dennyt; 01-21-2011 at 06:32 PM.. Reason: changed CP to stagnation point
Old 01-21-2011, 07:46 PM   #10 (permalink)
in tents
dennyt's Avatar
Subaru
Ski boxes should be fully faired-in. Like this!
