09-06-2020, 07:12 PM
Cyborg ECU
https://www.motorauthority.com/news/...-than-expected
Despite the “1400” in the name, the powertrain of the Mustang Cobra Jet 1400 is very different to the one in the Mustang Mach-E 1400 prototype. In the drag racer, there are four electric motors, and these power the rear wheels only. The electric crossover SUV had seven motors split three at the front and four at the rear.
In the Mustang Cobra Jet 1400, each motor is paired with an inverter, and each of these motor-inverter packages run at 800 volts and up to 700 amps with a maximum output of 469 hp. All four motors don't produce their peaks at the same time, which is why the combined output is lower than if you simply multiple the peak output of an individual motor by the number of motors present.
